Cutting Acrylic Light Diffuser Panels - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-13-2010, 08:00 AM   #1
Cutting acrylic light diffuser panels
What is the cleanest and fastest way to cut these panels. I have straight cuts and curved cuts to make
mlm1942 is offline   Reply With Quote
Old 08-13-2010, 08:32 AM   #2
Superintendent
Mudpad's Avatar
Anything with a fine toothed blade.
Mudpad is offline   Reply With Quote
Old 08-13-2010, 09:02 AM   #3
the Musigician
DangerMouse's Avatar
Even then, the cuts can still 'chip out'. If this starts, you can minimize it by putting masking tape over the line you need to cut. Remove tape immediately after the cutting is done. Like MudPad said, the finer the teeth, the smoother the cut. You'll need to use a sabre saw (jigsaw) for rounded cuts.... go slow and be careful.
DM
Old 08-14-2010, 06:01 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
There is also a small "hook-knife" used to cut these panels. The pebbled surfaces create a challenge but it is do-able. The smooth surface panels are easiest. The hook-knife digs out a small quantity of (plastic) with each pass as you "drag" it, then at some point the panel can be deliberately and neatly broken along the gouge made with the knife. It works for curves also.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
mlm1942 (08-16-2010)
Old 08-14-2010, 08:20 PM   #5
jlhaslip's Avatar
Rewards Points: 2,140
the 'hook knife' that would work for me is a carbide tipped one suitable for laminates.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 08-15-2010, 05:48 PM   #6
Old School
cabinetman's Avatar
I use an ordinary utility knife and make several passes and snap off the waste.
cabinetman is offline   Reply With Quote
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
How to cut acrylic light diffuser panels theseeker Electrical 21 07-21-2014 06:01 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Decorative acrylic cabinet door panels..... SandyK General DIY Discussions 1 02-20-2009 03:00 PM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 07:11 PM
