Customized Ikea Sink Cabinet - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 11-12-2014, 08:49 PM   #1
Rewards Points: 42
Question
Remodeling my kitchen with Ikea Akurum cabinets, but due to the layout, the sink will be in a corner and will have to be custom-built with only the sides and front doors/false drawers to be used from a base Ikea 30" cabinet.
I try to avoid particle board bottoms for sinks as much as possible and was looking at a 3/4" plywood solution but couldn't find any local sources for sheet melamine veneer, and ordering online will be expensive due to the shipping/handling.
Since Ikea cabinets are particle board/MDF and I would have used a stock cabinet if it would fit, and the fact that I'm retaining the Ikea sides, I guess I could use a 3/4" melamine sheet from the local HD for the bottom.
Thoughts one way or another? Tips on water-resisting these melamine sheets, such as caulking all seams, joints, and holes? Go with plywood and bite the bullet on melamine sheet veneer cost?
Augster is offline   Reply With Quote
Old 11-12-2014, 09:49 PM   #2
Rewards Points: 81
I like to put sheet vinyl on the floor of my sink cabinets. So I'd use the plywood with a vinyl top layer. You could also just paint it with a high quality, high gloss, exterior paint.
MaineLL is offline   Reply With Quote
The Following User Says Thank You to MaineLL For This Useful Post:
Augster (11-12-2014)
Old 11-12-2014, 09:52 PM   #3
Rewards Points: 42
Do you do anything to hide the edges of the vinyl sheet? Any adhesive or "floating?"
Old 11-12-2014, 10:03 PM   #4
Rewards Points: 81
Sometimes I'll use a metal transition strip at the front, where it is most likely to get caught. If I'm feeling really fussy, I might put some trim on the edges to hold it down.
I also know someone who uses sheet laminate on the bottom. That would avoid the issue of edges curling up.
Old 11-21-2014, 07:08 AM   #5
Rewards Points: 660
Before the assembly, I coat top, bottom and side edge with silicon except the back. That goes for sides that will contain the dishwasher too. The sink case gets extra protection with sticky liners on bottom, wrapping the corner.
carpdad is offline   Reply With Quote
sink water coming out from under kitchen cabinets (not in the cabinet) junesmith54 Plumbing 2 06-09-2013 09:26 AM
Pedestal Sink Vanity / Cabinet splintner Remodeling 7 05-03-2013 09:01 AM
Peninsula Sink removing Pony wall becomes Island Plumbing? lothia Plumbing 6 04-30-2013 12:13 PM
Open Sewer pipe under sink cabinet NoName Plumbing 4 02-03-2011 09:20 AM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
