Crack In Grout Near The Ceiling......a More Serious Issue? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 12-29-2009, 11:34 AM   #1
Question
Crack in grout near the ceiling......a more serious issue?
I'm trying to figure out if I should worry about this or if might be typical (or even acceptable).
This bathroom was gutted and had a corner shower put in with a vinyl pan. These pictures are of the ceiling area. 1/2" Hardie is behind the tile. Flexabond thinset was used. Redguard was used in the shower area, starting 12in from the ceiling.
Only things I can think of is the temperature. It's upstairs and not currently being used, so it stays in the 60* range, or less. The other is that the right corner wall is against a chimney, but it doesn't get hot, plus there is an air space between the chimney and Hardie from the furring strips.
I can live it that for now, I'm just hoping it's not a more serious issue. Should this be re-grouted? I have caulking that matches the grout. Should that be used? Thanks.
http://imgur.com/Bp3WV.jpg
http://imgur.com/1hv8X.jpg
http://imgur.com/ULUEy.jpg
http://imgur.com/gUEBJ.jpg
HautingLu is offline   Reply With Quote
Old 12-29-2009, 11:37 AM   #2
Remodeling Contractor
Caulking should be used. The grout will always crack along materials that expand and contract differently.
Old 12-29-2009, 11:41 AM   #3
That's reassuring.......I was starting to get worried (though the 2nd bathroom with a similar layout shows no signs of any cracks).
Like I said, I haven't used the shower yet (no curtain). Should I though, to wet the grout and such?
Thanks.
Ceiling Crack Repair Speckert Building & Construction 7 12-29-2008 10:03 AM
found an old foundation crack in block floor to ceiling flashme18 Building & Construction 14 11-11-2008 09:15 PM
Tinting/re-coloring grout proofer Flooring 7 02-02-2008 10:59 PM
ceiling fan instal issue mikpowl Electrical 3 09-10-2007 12:21 AM
How would you fix this cosmetic ceiling issue? tinhouse General DIY Discussions 6 08-24-2007 12:12 PM
