Countertop Installation - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-20-2010, 11:30 AM   #1
countertop installation
Is it recomended to glue countertops to cabinets or just use screws?
jack bond is offline   Reply With Quote
Old 08-20-2010, 02:35 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 792
Jack you can do it either way, or both. I used caulk or silicone to glue down most of my counter tops. It will hold the tops in place well and if you need to remove the top you don't need a sledge hammer.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 08-20-2010, 09:23 PM   #3
jlhaslip's Avatar
Rewards Points: 2,884
screws
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 08-21-2010, 05:55 AM   #4
Screws make sure it is pulled down flat on the cabinets. Use a dab of silicone adhesive if you like, but once screwed down, it won't be going anywhere.
Old 08-21-2010, 10:59 AM   #5
jlhaslip's Avatar
I have only used caulking when the countertop won't allow for screws. IE: concrete, granite or man-made products.
Old 08-21-2010, 11:05 AM   #6
Mabc's Avatar
For countertops that can be screwed down I use coated deck screws, and for countertops that can't be screwed down I use silicone.
Mabc is offline   Reply With Quote
How to install countertop over washer and dryer R V Dunai Remodeling 13 08-21-2011 02:07 PM
receptable inside cabinet DIYGST Electrical 8 01-29-2010 07:05 PM
countertop installation - stove/oven issue diycarguy Building & Construction 12 05-04-2009 01:08 PM
granite tile countertop installation had Building & Construction 3 04-01-2009 05:30 AM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 12:19 AM
