Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 07-01-2012, 12:21 PM   #1
countertop build-up
hey all,
I bought some post form laminate countertops and have questions. they tell me I need to put wood blocks 3/4" tall under the countertop (build up) and my questions is should I cut 3" long blocks like they said at HD or can they be longer and in any case how far should the blocks be spaced apart?
I was wondering if it would be more stable to have long pieces like 3 foot lengths with a few inches gap to have under the whole length? would that be more stable? prevent sag? or are 3" blocks standard for a reason?
thanks much!
petros151 is offline   Reply With Quote
Old 07-17-2012, 07:39 PM   #2
mikemakeitso's Avatar
countertop build-up
Hi, did anyone ever reply to this question?
mikemakeitso is offline   Reply With Quote
Old 07-17-2012, 08:25 PM   #3
countertop build-up
Not sure why you would use spacers and not full lenght pieces of 1 X 4's.
By making then full lenght the top is fully supported so it will not sag or crack if someone sits or leans on it.
1 X 4 spruce is cheap to buy.
petros151 (07-17-2012)
Old 07-17-2012, 08:30 PM   #4
countertop build-up
Good point.
I don't want to hijack this thread but was wondering what type of countertop build-up would be required for outdoors using cinderblocks as the base? (for example, i don't think pressure treat wood is the right choice)
Old 07-17-2012, 09:57 PM   #5
countertop build-up
thanks, the lead down that spacer path was because the guys at HD sell these spacer kits little blocks so I wondered if that is standard.
I am getting the buildup done with full length 1x4 pieces works well.
Old 07-17-2012, 10:12 PM   #6
countertop build-up
He may have been trying to sell you shims to correct out of level cabinets.
The shim need to go under the cabinets not under the top.
If the cabinets are level from front to back and from side to side then there's no need to shim the counter top.
What is best way to build a detached 24x24' Garage with a Basement underneath? eastpamt1 General Discussion 10 12-07-2011 01:10 PM
How to install countertop over washer and dryer R V Dunai Remodeling 13 08-21-2011 03:07 PM
Tiling over the outdoor kitchen countertop nmikmik Flooring 4 06-17-2011 09:57 AM
How to remove cultured marble bathroom vanity countertop goshenplumber Building & Construction 4 03-04-2011 05:56 PM
Marble countertop excess length doesn't leave enough space for stove! sbrink Kitchen & Bath Remodeling 1 12-28-2010 05:21 PM
