Countersink Size? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-04-2012, 03:26 PM   #1
Rewards Points: 170
Countersink size?
I need to countersink a long screw in one of my door jambs that seems to have pulled too tight with the expansion due to the weather warming up. What is an average size screw head?
#6
#8
#10
I'm using the common screw you find at home depot that is about 3.5" long and is coated for outdoor use, forget the brand. Doesn't say the head size on it anywhere. Anyone know what # this common screw head is?
I'm debating on buying the pack with all 3, or just get the 1 that I will need:
http://www.amazon.com/DEWALT-DW2535-.../dp/B0000225OU
HandyFrank is offline   Reply With Quote
Old 05-04-2012, 05:03 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
if your using a 3 1/2 " screws more than likely their #10's with the longer shank you need a larger head to provide more holding power
woodworkbykirk is online now   Reply With Quote
Old 05-04-2012, 05:07 PM   #3
Rewards Points: 170
Thanks for the input. Maybe i'll just grab the 3 pack so I have it for future projects.
wire size for 1575 inverter 15' from battery bluemoonshine Electrical 8 12-28-2011 10:49 AM
Rule of Thumb for Trowel size and Spacer size please.. K.M.G Flooring 7 02-08-2010 09:13 PM
Determining Boot/Register Size Earnie HVAC 15 12-31-2009 06:00 PM
What size and type of nails to use keviadams General DIY Discussions 2 09-28-2009 01:25 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 01:08 AM
