Corner Whirlpool Tub - Kitchen & Bath Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-18-2012, 09:02 PM   #16
Renovations contractor
Bonzai's Avatar
You could do a shaker panel out of birch 3/4" plywood (for the centre) and maple 1x3 or 1x4 frame (depending on how big the overall panel is so that it works proportionally) ... Stain or paint it to match your vanity. If this is going to be too big and possibly warp (I've no idea how big your tub is) then you could do one fixed centre panel and removable matching panels on either side depending where you need access. Hope this makes some sense. Depends if you're up to making cabinet door panels as that's basically what's am describing. I would use this sort of catch to attach to the framing ... http://www.richelieu.com/en/catches-...c?idGr=1004730
Other than for looks and durability (the edge of plywood is not good for taking dings) the reason for the shaker is so that you don't have the plywood edge exposed to potential moisture issues from people getting in/out of the tub.
Hope you can visualize well ;-)
Home Renovations & Repairs
ADVENT HOME SOLUTIONS INC
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
Old 11-30-2012, 04:59 AM   #17
Corner whirlpool
This is the whirlpool I worked .Thanks for all the advice!
luckybodog is offline   Reply With Quote
crown molding fitting problem momof2labs Carpentry 16 10-15-2011 12:45 PM
Inside corner on small corner jburchill Drywall & Plaster 0 09-21-2011 10:08 PM
Floor Support needed for Jacuzzi Corner Whirlpool tub kuecs1 Building & Construction 0 06-10-2010 11:15 PM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 10:16 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
