Corner Tile In Tub Area - Kitchen & Bath Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-02-2010, 10:14 PM   #16
how would you guys fix this? i want to just tile to the top of the board, then fill in the ceiling with joint compound. but i have a feeling it needs taped.
http://img269.imageshack.us/img269/2307/tilez.jpg
and also where the tile meets the drywall, i somehow
ended up with a rough cut, and some big gaps.1\8" or a little begger.i know they are to big to fill with thinset. what would i need to use before i tape it?
this forum is savin my but
fishtale is offline   Reply With Quote
Old 08-03-2010, 07:30 AM   #17
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What's the compound you used in the verticle corner already?
How much money did you save by not using the recommended amount of screws in the wall board?
XXX
Old 08-03-2010, 11:31 AM   #18
acrylpro is what i used.
and i have screws left over.
i got them about every 8-10"
is that not good?
any tips on my other questions would be great. thanks again.
and sorry about needing all the help
Old 08-03-2010, 02:03 PM   #19
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Thought so! Acrylpro is a premixed mastic and mastic is what we are warning against when used in showers. It (mastic) has been known to re-emulsify when it gets wet. It is not suitable for tile in wet areas in a lot of cases and it certainly isn't suitable to run joints with for the same reasons.
I know, I know, the instructions say it's used for showers but it doesn't work that well and is problematic. Mastic has its place but a wet area isn't it. Get rid of that crap!
and i have screws left over. i got them about every 8-10" is that not good?
Eight to ten inches? What does the backerboard maker recommend? In the picture I didn't think I was seeing screws eight to ten inches apart, it looks like much more. Also, the board needs to be screwed to each stud. What is the stud spacing of that wall?
Well yow !!! That gaping hole at the top begs to be filled. But NOT WITH ACRYLPRO! I would fill it with thinset. Mix it stiff, fill the gap, tape over the fill and make another pass. Expect the thinset to sag and be a huge pain in the butt. If you mix it thick enough it won't sag real bad but it will sag. Once it is dry, you'll probably have to grind it some with a square rub-stone. A gap that big is a mistake...but, OH WELL!
That's not at all a problem...keep asking questions. Maybe you should always "ask" BEFORE you move ahead!!!
OK, what else? What did I miss?
XXX
Old 08-03-2010, 07:38 PM   #20
i am gonna redguard everything, and this is my wifes bathroom. i installed a jacuzzi tub and she HATES showers. so it might not ever see a shower. i am just gonna hope it works out ok.
and vthe studs are 16"
the pic does look like the screws are farther .
and i was left with the gap on the ceiling because the old walls were much thicker.
im no expert. "like u didnt know"
just a first time homeowner having fun.
thanks for the info
Old 08-03-2010, 07:50 PM   #21
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You'll do fine, go for it.
XXX
Old 08-03-2010, 08:40 PM   #22
cool. i was not going to use the acrylpro for the tile.i got versabond for that
Old 08-03-2010, 09:24 PM   #23
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Good Deal!
Throw away the Acrylpro but SAVE THE BUCKET. Those buckets are excellent for mixing thinset and then being able to dip it out of the bucket with a notched trowel.
XXX
Old 08-05-2010, 11:39 AM   #24
should i tape the corner bead???????
Old 08-06-2010, 07:04 AM   #25
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I do, but I'm not sure it is totally necessary.
XXX
Advice for new patio area Mike2181 Landscaping & Lawn Care 2 07-19-2010 08:48 PM
Peel and stick vinyl flooring over absteos tile? Codchamp Flooring 3 07-17-2010 06:17 PM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 03:06 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
Stick-on tile over Stick-on tile Chris_Old_House Flooring 2 09-27-2008 08:45 AM
