Corner Tile In Tub Area - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-31-2010, 01:50 PM   #1
corner tile in tub area
what knida corner piece do i use for the 90* angle thats gonna have tile on one side and just grywall on the oher side.
is there a corner brace that has tape on the side the tile goes over?
and do i tape everything, the redguard it all?
thanks in advance
fishtale is offline   Reply With Quote
Old 07-31-2010, 02:34 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
WOW! That's really a tough read.
I think you must be asking about a "bullnose" tile used to terminate wall tile. Does that sound correct?
XXX
Old 07-31-2010, 03:26 PM   #3
dang, that is rough.ill try again
the three walls around the tub now have hardybacker. corners and seams are taped.
but like when you mud a drywall corner, you use that corner bead. to make it strong. would something like that be used. one side would be under the bull nose. and the other side will float into the wall?
second?
do i redguard everything. even the taped seams?
thanks
Old 07-31-2010, 03:41 PM   #4
heres a link to the pic of it
http://img688.imageshack.us/img688/5994/wallby.jpg
Old 07-31-2010, 04:01 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
OK, now I'm catching up I think.
The (outside) corner you are pointing to would not require anything additional be done IF you are going to wrap that corner with tile. Bullnose would be required on only one face, wouldn't matter which one.
If the tile (bullnose) is to terminate at that location and not go around the corner then, YES, a outside corner bead would be used at that location and then be filled with joint compound ONLY on the side nearest the door. Thinset mortar would be used on the shower side of that corner bead.
Are we getting closer?
XXX
Old 07-31-2010, 06:50 PM   #6
thanks, what kind of corner bead?
there so many different ones
Old 07-31-2010, 08:20 PM   #7
Just a metal corner bead. Make sure the corner of it sits proud of the drywall so the mud fills the gap.
mrgins is offline   Reply With Quote
Old 08-01-2010, 10:08 AM   #8
i had a plastic one already. will that be ok, or is the metal one thinner?
and im just not sure how much mud to leave under the bead. thanks
Old 08-01-2010, 11:51 AM   #9
You can use plastic. I always use a spray adhesive when I use plastic but make sure you don't get any on the finished .ceiling or floor. 3M makes a good one. After that just apply joint compound on it.
Old 08-01-2010, 01:02 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That is your best bet - DON'T use a metal corner bead.
You DO NOT put any mortar under the bead. The bead is to be glued and maybe stapled to the dry wall board be it cement board or drywall. THEN you apply thinset mortar to the side to be tiled and drywall compound to the side to be painted.
You still haven't answered the question about the tile going around the corner. Does the tile go to the door frame OR NOT? You may not even need the corner bead as stated earlier in the thread.
Re-read the entire thread, you are getting lost in all the information maybe.
XXX
Old 08-01-2010, 05:10 PM   #11
ok. i think i got it.i do need the spray glue because there is nothing behind there to grab a screw good.
and the tile is not goung to the door. just the three walls behind tub.
thanks
Old 08-01-2010, 06:48 PM   #12
man, that spray glue works pretty good
how long till i can use thinset on it?
Old 08-01-2010, 07:58 PM   #13
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Immediately. Go for it!
XXX
Old 08-02-2010, 05:15 PM   #14
Bud, I've never had problems using metal corners in that situation. Thats what they used until plastic corners came on the market. Have you had bad experience with them?
Old 08-02-2010, 05:23 PM   #15
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I have torn out many many many rusty outside corners in my time. Now that plastic is available it's a step up. Even if moisture didn't get to the metal, the alkali in thinset would over time. Those corners have never been alkali resistant. I have removed tile where there was at one time a metal corner underneath and the metal was totally gone in some places, it just vanished.
Metal used under gypsum was never an issue but used under cement products is a different story I suppose.
XXX
Advice for new patio area Mike2181 Landscaping & Lawn Care 2 07-19-2010 08:48 PM
Peel and stick vinyl flooring over absteos tile? Codchamp Flooring 3 07-17-2010 06:17 PM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 03:06 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
Stick-on tile over Stick-on tile Chris_Old_House Flooring 2 09-27-2008 08:45 AM
