Corian Top Removal From Undermount Sink Without Breaking Top Into Pieces. - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-27-2013, 10:51 AM   #1
Corian top removal from undermount sink without breaking top into pieces.
My contractor said the corian top to my undermount sink will break into pieces when it is removed. Is there a way to remove it without breaking the corian top I just love? I want to change my undermount sink color and the sink needs to be removed. Is the contractor just taking the easy way out and not allowing sufficient time for the removal?
Nanas5 is offline   Reply With Quote
Old 01-27-2013, 11:00 AM   #2
Rewards Points: 13,300
I might have told you it might break and make you sign a statement stating that but in most cases it can be removed.
Not a job for the faint of heart.
Old 01-27-2013, 11:38 AM   #3
What he said........, it might break, not it will break, and not into pieces. Tops are usually held in place with dabs of silicone caulk around the perimeter, not a continuous bond around the whole perimeter. Proper use of a long putty knife usually frees things up.
A good thing about Corian........it can be repaired so the seams are barely visible.
Old 01-27-2013, 12:05 PM   #4
DIY staff
Rewards Points: 7,174
Is the sink made of corian also?
Old 01-31-2013, 07:55 AM   #5
Old School
cabinetman's Avatar
What happened to the OP? It would be worthwhile to have a crew that is experienced with Corian.
cabinetman is offline   Reply With Quote
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 08:07 AM
sink removal dumhomeowner Plumbing 4 07-08-2008 12:38 PM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 09:43 AM
Help with construction of laundry sink VokinLoksar Plumbing 3 07-06-2008 07:42 PM
replacing sink in corian vanity top jaybee General DIY Discussions 2 09-01-2007 03:08 PM
