Where can I buy this "Art Specialties International, Inc. Super Thin CA"?
After applying heat with hair dryer, is the crack supposed to be closed? If the surface is not aligned, I guess I will have to hold the surface to line them up during the entire procedure?
When applying the CA, how do I know the CA will go through the crack if the seam is closed by heat already? I read it from here:
http://www.thefabricatornetwork.com/...2/Default.aspx
that somebody actually apply the CA before applying heat.
How much CA should be applied? I suppose I will see the excessive liquid along the crack after applying it. Shall I use the paper towel to wipe if off immediately after I apply it?
Thank you very much!
Originally Posted by Ken Dolph
