Converting Bath To Shower - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-02-2013, 07:08 PM   #1
Converting Bath to Shower
My wife wants to remove an outdated jetted tub on the second floor of our home and replace it with a shower. My understanding is that I need a 2" drain. The existing bath tub has a 1 1/2" drain. Can I leave the 1 1/2" vent pipe when I replace the drain pipe with a 2" pipe or will I need to make the vent pipe to through the roof 2" also?
BobOB1775 is offline   Reply With Quote
Old 05-02-2013, 07:57 PM   #2
DIY staff
Rewards Points: 7,174
You will be fine with a 1 1/2" vent----that will work well and meet code---
ddawg16 (05-02-2013)
Old 05-02-2013, 08:07 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,810
Mike is right....1 1/2" vent is fine.....assuming you don't have a bunch of other stuff on it....there is a formula for calculating it....
Just a little background....as I understand it....a bathtub can drain slowly....you have a tub holding the water.....but on a shower, there is no 'tub' to hold the water....hence, it needs to drain out as quick as possible....hence, the 2" drain....
Old 05-02-2013, 08:10 PM   #4
DIY staff
Yikes---1 1/2 VENT is fine---drain must be 2"----
Old 05-02-2013, 08:12 PM   #5
JOATMON
ddawg16's Avatar
Thanks Mike.....vent, drain.....what ever it takes.....long day....
Old 05-02-2013, 09:09 PM   #6
Rewards Points: 236
i have a 1 1/2" drain in my shower. NO issues what so ever.
Fix'n it is offline   Reply With Quote
Old 05-03-2013, 06:19 AM   #7
DIY staff
Times change and codes change----2" is code --and hair and crud cause enough slow 2" drains that choosing 1 1/2" when remodeling is just a poor choice.
Old 05-04-2013, 07:54 AM   #8
Rewards Points: 236
yeah. there was 1 1/2" in there already. so when i replaced it, i just went with the same size. when i redo the bathroom, i will code it all.
The Following User Says Thank You to Fix'n it For This Useful Post:
oh'mike (05-07-2013)
Help with shower pan removal - 1960s bath jm71 Kitchen & Bath Remodeling 6 11-23-2009 07:54 PM
Hiding shower pipes Jackamus Kitchen & Bath Remodeling 2 10-29-2009 04:30 AM
one piece shower bath unit. this old house Building & Construction 2 11-16-2005 09:10 PM
Adding a shower to a 1/2 bath amyjean Plumbing 1 09-10-2005 07:06 PM
