-   Kitchen & Bath Remodeling (http://www.diychatroom.com/f80/)
-   -   Converting Bath to Shower (http://www.diychatroom.com/f80/converting-bath-shower-178622/)
BobOB1775 05-02-2013 08:08 PM
My wife wants to remove an outdated jetted tub on the second floor of our home and replace it with a shower. My understanding is that I need a 2" drain. The existing bath tub has a 1 1/2" drain. Can I leave the 1 1/2" vent pipe when I replace the drain pipe with a 2" pipe or will I need to make the vent pipe to through the roof 2" also?
oh'mike 05-02-2013 08:57 PM
You will be fine with a 1 1/2" vent----that will work well and meet code---
ddawg16 05-02-2013 09:07 PM
Mike is right....1 1/2" vent is fine.....assuming you don't have a bunch of other stuff on it....there is a formula for calculating it....
Just a little background....as I understand it....a bathtub can drain slowly....you have a tub holding the water.....but on a shower, there is no 'tub' to hold the water....hence, it needs to drain out as quick as possible....hence, the 2" drain....
oh'mike 05-02-2013 09:10 PM
Yikes---1 1/2 VENT is fine---drain must be 2"----
ddawg16 05-02-2013 09:12 PM
Thanks Mike.....vent, drain.....what ever it takes.....long day....
Fix'n it 05-02-2013 10:09 PM
i have a 1 1/2" drain in my shower. NO issues what so ever.
oh'mike 05-03-2013 07:19 AM
Times change and codes change----2" is code --and hair and crud cause enough slow 2" drains that choosing 1 1/2" when remodeling is just a poor choice.
Fix'n it 05-04-2013 08:54 AM
yeah. there was 1 1/2" in there already. so when i replaced it, i just went with the same size. when i redo the bathroom, i will code it all.
