Ceramic Tile - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-21-2012, 12:35 PM   #1
Ceramic tile
Can i put the cement board over the old linoleum, then put down tile?
bking3253 is offline   Reply With Quote
Old 03-21-2012, 12:53 PM   #2
Rewards Points: 13,300
No, the linolium and any 1/4 plywood, and or partical board needs to go first.
You also need to be taking a lokk at what subflooring you have, the widths of the floor joist, the lengths of the unsupported spans.
Tile can be laid over anything that flexes or moves.
Old 03-22-2012, 04:04 AM   #3
Why can't you put cement board over the linolium considering cement board is solid? Linolium, if it's still good, is already pretty flush with the floor. I don't see how you would have much if any flexes if laid over? Just not good practice? Or?
JasonCA is offline   Reply With Quote
Old 03-22-2012, 05:28 AM   #4
DIY staff
Rewards Points: 7,174
The 1/4" underlayment under the sheet goods makes for an unstable sandwich---
It might be successful but 'Might' is kind of risky to tile over.
Old 03-22-2012, 07:21 AM   #5
Can you, probably, should you NO!!! This will raise the floor 1/2" + the tile thickness and leave a high toe stubber from the next room. If in a bathroom, you will have issues getting the toilet installed(needs new or add on flange)
ceramic tile stain kivy Flooring 10 04-09-2012 07:57 AM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 08:48 PM
Could use some help on ceramic vs duraceramic tile helpmike Flooring 17 03-29-2011 11:42 PM
Replacing Ceramic tile floor handy andy Flooring 4 03-28-2011 01:07 AM
a couple of ceramic tile install Q's DanBress Flooring 5 06-22-2008 11:01 PM
