Cementboard-bathtub Joint Question With Picture - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-22-2012, 04:19 PM   #1
Rewards Points: 1,062
cementboard-bathtub joint question with picture
When joining the bathtub with cementboard, does the cementboard need to lap this perpendicular lip of the tub (see attached) or just butt it above?
Old 04-22-2012, 05:13 PM   #2
Cement board overlap.
The cement board does not have to overlap the lip on the tub. It should sit directly on top of the lip. After the cement board is fastened to the studs, your wall tile should overlap the lip, and once your ready to grout, it's better to get a bead of waterproof caulk along the bottom edge of the bottom tile all the way around. There is a special "grout caulk" you can buy for this at just about any home improvement store.
http://richeyconstructioncincy.com
gaber26 is offline   Reply With Quote
The Following User Says Thank You to gaber26 For This Useful Post:
amakarevic (04-22-2012)
Old 04-22-2012, 05:32 PM   #3
Smile
awesome! thanks
Old 04-22-2012, 08:31 PM   #4
Woah.. you nailed your tub directly to the stud? I thought you were supposed to nail just above the rim.
DIYGuy2012 is offline   Reply With Quote
Old 04-22-2012, 08:49 PM   #5
Rewards Points: 264
Some guys will shim the studs and let the backer board land halfway down the inside of the flange.
The guys at John Bridge can point out the options.
http://www.johnbridge.com/vbulletin/index.php
For what it is worth, the Kohler tub I installed showed the backer to overlap the inside of the flange.
7echo is offline   Reply With Quote
Old 04-22-2012, 10:33 PM   #6
i drilled holes in the tub and nailed through. why, does it matter?
Old 04-23-2012, 07:45 PM   #7
Rewards Points: 264
Some mfgs say to use a nail with a large head, like a roofing nail, and to nail it into the stud just above where the flange ends. So the nail head captures the flange against the stud, but it isn't through the flange.
What model and mfg is the tub? They will probably have instructions online.
Old 04-23-2012, 08:05 PM   #8
I am no pro by a long shot but I would think that nailing through the tub doesnt allow for expansion and contraction without moving the stud that it is attached to slightly. That might cause your grout to crack. I'd be interested in what others thought. Maybe ask a pro?
Plaster to drywall joint question. ERIK2173 Remodeling 7 05-16-2009 04:58 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
Ball and Socket Joint Question lateralan Carpentry 9 04-25-2008 09:12 AM
Newbie question about crack in PVC joint LinusInPW Plumbing 8 11-16-2007 11:25 PM
joint compound question golfer General DIY Discussions 3 01-09-2006 06:19 AM
