Cement Board Won't Line Up In Shower - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-11-2010, 06:37 AM   #1
Question
Cement Board Won't line up in shower
I installed cement board onto the studs in constructing my new shower stall, but some of the boards don't line up with the others. In my effort to fix it, I taped the joints and used thin set to slope the gap. But I'm not sure if this was the right thing to do. Please help.
elester01 is offline   Reply With Quote
Old 05-11-2010, 07:21 AM   #2
Rewards Points: 6,652
How large of a gap are we talking about? Something like this is caused by rushing the job and not taking the time to make sure it fits before securing.
Old 05-11-2010, 08:18 AM   #3
fabrk8r
fabrk8r's Avatar
This is probably a dumb question for the OP, but, do your cement board joints meet on the stud?
I don't see how there could be much variation in joint height if both pieces are screwed to the same stud.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 05-11-2010, 08:26 AM   #4
Military Mom of 4
Snav's Avatar
This is often caused by some studs bowing out a bit - or others being more narrow than a regular stud. But it could also be caused by some screws just not bringing the cement board in enough - leaving a gap (fixing this requires re-entering the screw or a new screw and checking for flushness)
Your idea of filling the uneven portion was the right thing to do as long as your joints are on the stud - but you need to feather it out more. . .work the mortar so it makes that transition VERY spread out - maybe transitioning over the space of 12".
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Tags
bath remodel , bath remodelling , cement backer board , cement board , shower remodel
Cement Board to Green Board Question ryan5068 Tiling, ceramics, marble 10 05-12-2010 06:29 PM
Poly behind cement board? toolbelt Tina Flooring 1 05-30-2009 10:52 PM
cement board corners ponch37300 Kitchen & Bath Remodeling 3 01-25-2009 05:50 PM
Remove 3/4" oak floor before cement board and ceramic tile goes down?? 4just1don Flooring 8 10-31-2008 10:32 AM
Bathroom remodel - lighting over shower / water line s4alex Electrical 15 10-10-2008 01:15 AM
