Cement Board W/Green Board Vs. Fiberock ? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 09-03-2012, 02:05 PM   #1
Cement board w/Green board vs. Fiberock ?
I am currently renovating my bathroom due to loose tiles that were placed on top of drywall that is now moldy and falling apart. I have torn out all of the tiles & walls from around the bathtub and want to replace it with a waterproof barrier and cement board.
The issue that I have run into is that the cement board is 1/8" thinner than the drywall that is around the rest of the bathroom. I have not tried to put the cement board up yet because I have been trying to find a solution to this problem (i.e. 1/8" shims or someone who can give me advice on how to remedy the situation).
I was looking at ideas on youtube yesterday and came across a new type of backer called Fiberock Tile Backerboard. It is waterproof, and can be tiled or painted. I was considering removing all of the walls in my bathroom and putting this up instead so that I can tile around the bathtub and just paint the rest, and not worry about a transition point between the cement board & green board. Does anyone have any experience with this product, or any advice on the 1/8" difference in wall thickness? (The rest of the walls in the bathroom have old wallpaper that has been painted on top of, so I wouldn't mind removing the rest of the walls just to get rid of the ugly bubbles & ripples in the painted-over wallpaper.)
Missjeanius is offline   Reply With Quote
Old 09-03-2012, 05:15 PM   #2
Rewards Points: 3,130
If it were me (and I have done what you're looking to do), I'd tear out everything down to the studs. Why do half a job??
Old 09-03-2012, 06:31 PM   #3
that would be your call. the backer board would cost you over twice as much as drywall. i would shim the 1/8 inch. don't forget to waterproof either behind or over top of the cement board.
Old 09-04-2012, 09:45 AM   #4
Shim out the area with "butt shims" (drywall shims, furring strips). They are available at H.D. in the drywall department. These strips are 1/16" thick, so you may need two to achieve the proper thickness.
Work is for those who can not fish.
Mop in Hand is offline   Reply With Quote
Tags
backer board , backerboard , cement board , fiberock , green board
yet another cement board question echobravo Kitchen & Bath Remodeling 4 01-23-2012 05:39 PM
Installing Stone Veneer to cement board on a wall Augy Building & Construction 2 01-20-2012 07:17 AM
Laying cement board on top of leveling concrete. dswenson Flooring 3 01-04-2012 08:26 PM
Cement Board to Green Board Question ryan5068 Tiling, ceramics, marble 10 05-12-2010 07:29 PM
Laying cement board oguevarra Flooring 18 12-16-2009 10:21 AM
