| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
The dry-mortar method is an easy way to fill the space in masonry joints when you're building a patio. One of its advantages is that the mortar keeps those pesky weeds from sprouting. Whether you're using bricks or concrete slabs, consider filling the... Read More »
How to Do Stone Masonry
by eHow.com
Stone masonry structures are beautiful and very intricate. For large jobs, you must have a professional come in to do the work. However, you can perform smaller stone masonry jobs without the expense of hiring a professional stone mason, by learning the... Read More »
Transferring Mosaic Tile Design Patterns to Backing Material
by Expert Village
I’m now going to transfer my design onto the backing material. And so on this backer board I placed a piece of carbon paper and then I placed my design onto that. And made sure my edges are lined up. And then I trace around the design like so. Make... Read More »
How to Fill Gaps in Brick Mortar for Home Improvement
by Expert Village
If you have gaps in your mortar, you want to fix those to prevent animals and insects from getting inside, and also from water from running into the wall, because behind this is all wood and you don’t want it to rot. So what you can do is get some... Read More »
Mosaic Backsplash Design Plan
by Expert Village
The base of your mosaic is determined by your application. Since this mosaic is a kitchen splash, I decided to put the mosaic on the backer board that you put tile on to put a splash on a kitchen. And this is what the backer board looks like. You buy it... Read More »
