#1 |
Cement board
So I want to redo the bathroom in tile. All the way to the ceiling. Plus in the kitchen I want to throw stainless steel tile at the back wall by the stove, right up to the fume hood.
This raises questions. First question of course is what do I do about the bathroom ceiling? The floor and walls will be cement board; the ceiling will be painted... painted drywall, or can/should I use cement board? Second is should I use drywall/mastic in the kitchen, or cement board/thinset? If I go with cement board, should I do that just behind the stove, or also behind the sink, or go all the way and throw Hardiebacker against all the walls? If I put cement board behind the sink, how the heck do I paint it with all the not-smooth surface? Some kind of liberal use of latex-acrylic primer?
If you can't explain why, then you don't know what you're talking about. I'll keep asking until I find someone who does. |
#2 |
Super Moderator
Cement board
Tile and thinset are fine over drywall---the cement board is used only in the wet areas like the shower walls----
Noting gained by using backer board in the kitchen, Unless you have a steam shower--well painted drywall above the tile in the shower is just fine.
New members: Adding your location to your profile helps in many ways.--M-- |
| Display Modes | |
| Cement backer board over kitchen concrete slab | gtimk4 | Flooring | 2 | 02-19-2012 03:46 PM |
| yet another cement board question | echobravo | Kitchen & Bath Remodeling | 4 | 01-23-2012 05:39 PM |
| Installing Stone Veneer to cement board on a wall | Augy | Building & Construction | 2 | 01-20-2012 07:17 AM |
| Laying cement board on top of leveling concrete. | dswenson | Flooring | 3 | 01-04-2012 08:26 PM |
| Cement Board to Green Board Question | ryan5068 | Tiling, ceramics, marble | 10 | 05-12-2010 07:29 PM |
