Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 09-11-2004, 08:25 PM   #1
Ceiling fan wired with flex conduit?
A ceiling fan was placed where none had previoiusly been. A flex conduit was used externally. Is this using proper code? :confused:
CONCERNED is offline   Reply With Quote
Old 09-12-2004, 08:40 AM   #2
CONCERNED
Flex conduit type wiring is normally considered safe if routed properly but in many areas will not meet code expect for short runs. May areas allow a 3 foot wipe of it to be used generally to hook up stationary appliances. Such as garbage disposals, dishwashers, exhaust hoods. This allows an alliance to be hard-wired (not just plugged in) and still able to be pulled out for service, also allows for slight flexibility. My opinion if the run is wired correctly and proper use of size was used it should be safe. But to address your question, It may not meet your local codes. Every area can be different so I can't really answer that type of question. A local electrician should be able to. Just a note some areas do not even require the use of metal conduit they allow for plastic sheathed cabling.
Mgmopar
MgMopar is offline   Reply With Quote
