Ceiling Fan In Small Bathroom - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-28-2011, 02:40 PM   #1
ceiling fan in small bathroom
I have a small bathroom, and I want to install a small ceiling fan, because it gets so hot in there, is that advisable?
qvcviewer is offline   Reply With Quote
Old 04-29-2011, 07:46 AM   #2
Current codes requires exhaust fans in bathrooms. While this does not affect your's, a fan is always a good idea. Fans must exhaust outside. If the bathroom is on an outside wall, or has an open attic above, installation is fairly simple. If located towards the interior of the house, it becomes more difficult, but not impossible. As to sizing, measure the square footage, multiply by 1.5, that should equal the CFM of the fan.
Old 04-29-2011, 07:56 AM   #3
fabrk8r
fabrk8r's Avatar
Ceiling fans and exhaust fans are two different things.
A ceiling fan, while one could be installed if the space permitted, is probably not the best solution for a hot bathroom. All it would accomplish is a means to move the hot moist air around. A ceiling or wall mounted exhaust fan would do a better job of getting rid of the heat and humidity, provided there is a source of cooler dryer make-up air, such as a door grill or large enough opening under the door.
I think the fist approach should be to find out why the bathroom is so hot in the first place and find a remedy. For instance, is there enough insulation between the ceiling and a hot attic above? Is the sun beating directly against a poorly insulated outer bathroom wall?
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
HELP! Ceramic tiled ceiling in basement bathroom.... jrutherford Remodeling 1 10-11-2010 01:27 PM
Bathroom and textured ceiling painting? elementz Painting 6 10-01-2010 05:27 PM
Is it ok to use the shower without a ceiling in the bathroom? Bigguy0 Building & Construction 5 10-24-2009 08:26 PM
Bathroom Ceiling with radiant heat Chatterbox Painting 6 10-13-2009 04:16 AM
Best primer for bathroom ceiling dbldee20 Painting 11 01-06-2009 04:25 PM
