Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 01-12-2011, 02:54 PM   #1
Cedar Casement Windows In The Bathroom Shower
I will be remodeling two of my bathrooms which have cedar casement windows. Both windows have been stained again and again and protected by a clear plastic cover. It's time to remove the plastic.
Q. Is there a clear stain/varnish on the market that will seal & protect the wood frame/sill ?
I have no problem in replacing both of these windows, however cannot find a supplier that has windows with wood exterior and aluminum/vinyl interior. All I see is just the reverse; therefore I will not be able to match the exterior color of a new window with all the other windows.
Hope you see what I mean. All my windows have been maintained are in excellent condition both in/out.
All comments & suggestions would be very much appreciated.
Peter K is offline   Reply With Quote
Old 01-12-2011, 02:58 PM   #2
Experienced
Jackofall1's Avatar
Linseed oil is a good stain/protector.
Old 01-18-2011, 01:10 PM   #3
I'm wondering if you managed to find a wood window like these that would work to replace the old ones, would it still need something like linseed oil?
TomB is offline   Reply With Quote
Old 01-19-2011, 05:41 AM   #4
Stuck in the 70's
Blondesense's Avatar
Just to clarify: This window is in the shower?
If so, is the shower is used daily?
Do you have a pic?
There are spar or outdoor polyurethanes that may help.
That, using a good 100%silicone caulk, and trimming the sill at an angle so water won't sit on it may also help.
Even so, you want to be meticulous about the upkeep, and dry it off after showering.
Having wood in a shower is not a good idea. It tends to rot.
Having a window in a shower is not a good idea. It tends to be a weak spot for water entering and damaging the wall.
Hate to say it, but in a shower your best solution is to protect it from direct water hitting it. This pretty much means covering it back up or removing it entirely.
Old 01-19-2011, 06:33 AM   #5
Super Moderator
Torture Test for Outdoor Finishes - Powered by Google Docs
This article has a list of the toughest finishes available--a good read--Mike--
oh'mike is online now   Reply With Quote
Pella Casement Windows warmsmeallup General Discussion 35 09-17-2010 06:59 PM
cedar t$g in bathroom ceiling rtoni Building & Construction 0 08-23-2010 01:00 PM
Bathroom Shower jackco711 Flooring 4 11-14-2006 10:22 AM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
Bathroom shower sill installation question bocci Remodeling 2 07-23-2006 01:31 PM
