CBU Joint Issue? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-16-2011, 08:29 AM   #1
CBU Joint Issue?
I've finally finished my bathroom renovation and waiting for the shower enclosure to be installed. During the project, I took extra care to ensure that all joints were mesh taped with thinset and sealed with KBRS Shower Seal. This stuff is a rubberized membrane similar to redgard. After the joints were taped and sealed, I applied a coat of shower seal, embedded a 5" fabric strip along the joint, and topped it with 3 more coats of shower seal before tiling.
My question is this: Unfortunately I'm pretty sure I forgot to tape and thinset the right corner where the shower pan meets the tub as you can see in the picture. The wall comes up 18" and then over 3" that will be inside the shower. The joint is probably 1/16"- pretty much butted the joint since it was a small piece. As it sits, the 18" vertical joint is filled with a small strip of silicone, has a coat of shower seal in it, fabric strip, 3 more coats of shower seal, thinset, tile, and sanded caulk. The 3" horizontal joint has all of the above except the silicone. Could this possibly leak even though I forgot to tape the joint?
I completely brain farted when doing this section. Is it worth tearing it apart to tape the joint and redo? I'm afraid if i do so I'll do more damage than good.
I've attached a picture to help describe the area
cobrakai is offline   Reply With Quote
Old 01-19-2011, 09:11 PM   #2
Sounds like you have covered the bases pretty well. Will it leak? Maybe. I would redo it if it were for a customer. However, since it's yours, you have to make the call. (not so sure I would redo it, if it were mine). Looks pretty nice BTW.
Work is for those who can not fish.
Mop in Hand is offline   Reply With Quote
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
PVC Sprinkler Leak at T Joint D2D2 Landscaping & Lawn Care 3 08-26-2010 03:57 PM
Concrete floor prep for ceramic tile tpanc13 Flooring 39 06-22-2010 08:50 PM
Will joint compound stick to Zinsser 1-2-3? Lovegasoline Building & Construction 13 09-28-2009 10:55 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 05:50 PM
