Caulking Fiberglass Shower Surround - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-22-2012, 07:05 AM   #1
Caulking fiberglass shower surround
Do you suggest caulking along the bottom of the 3-piece surround (where it meets the tub)? I always have, but a friend claims there is a lip created there to prevent water from getting where it shouldn't go. We seem to agree on the need to caulk the vertical seams in the surround, but not the horizontal one along the top of the tub. I have had no problems with the caulk staying put...it just discolors with time and needs replaced. Thanks for your suggestions!
jakate is offline   Reply With Quote
Old 06-22-2012, 07:18 AM   #2
Rewards Points: 13,458
I would not do it, reason being is if water some how did end up behind the panels the caulking would act as a dam and hold it in.
There's a lip around a tub on three sides, so water would have to run up hill to be able to get in.
Old 06-22-2012, 09:51 AM   #3
Household Handyman
Rewards Points: 1,408
Personally I do caulk these when I install them. BUT--I run a small bead of caulk near the edge so that when I press the panel in place it will sort of "sqish" out. I let this set a few minutes then trim off only what can be seen. Along the bottom edge I skip about a half-inch (1/2") every foot for "breathing".
Shower surround with window freakinjosh Carpentry 5 10-19-2011 10:10 AM
Bathtub fiberglass surround schraggyj Tiling, ceramics, marble 2 08-21-2011 07:15 PM
Fiberglass shower stall scarrylarry Painting 2 02-24-2011 06:27 PM
Help us make a remodel decision for selling home pleas 3detailer Kitchen & Bath Remodeling 11 04-27-2010 11:36 AM
Backerboard under Fiberglass Shower Pan? BillyDIY Plumbing 2 12-17-2008 01:47 PM
