Caulking Around Faucet Rough-in? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-20-2012, 08:45 PM   #1
Rewards Points: 77
Caulking around faucet rough-in?
Quick question (Hoping for quick answer!)
Do I need to caulk the space between the shower faucet and cement board or do I just leave it as is? The fixture covers the entire hole.
shorteared is offline   Reply With Quote
Old 08-20-2012, 08:57 PM   #2
Rewards Points: 13,750
No caulking around that hole. I'd be double checking to make sure the rest of the fixture is going to work with the hole that tight.
Rember the plastic piece that cover that piece that's stick out of the wall? The hole needed to be big enough for that whole thing to fit in the hole.
And double check that it sticks out far enough allowing for the tile.
Better to find out now then after the tile goes up.
Is there a cover plate with screws in it to attach it to the valve? If so also check that you allowed room for the screws.
Old 08-20-2012, 10:41 PM   #3
AHH, SPANS!!!
Rewards Points: 1,166
I've been tripping over those round black pieces for years
They never seem to stay where they are supposed to - with the faucet assembly
hand drive is offline   Reply With Quote
Old 08-20-2012, 10:43 PM   #4
Rewards Points: 77
Thanks for quick reply JoeCaption,
Looks like everything fits when I put the fixture on, however it seems to protrude into the shower quite a bit, is this normal? Im thinking I will have to remove the drywall on the other side of the faucet and move the whole assembly back to correct this. any thoughts?
Old 08-20-2012, 11:01 PM   #5
There's suppost to be an access panel on the back side of that wall anyway.
They sell simple snap in ones at Lowes and HD in the plumbing dept. Buy the bigger one so you will have room to work if the need arises.
When I set the valve I predrill the 2 X 4 and toe nail it in place with ceramic coated decking screws, and leave the wall open. That way if I messed up I can adjust it.
shorteared (08-21-2012)
Old 08-20-2012, 11:03 PM   #6
Looks like you got skimpy with the thin set when setting that tape, there's to many holes and gaps showing.
Old 08-21-2012, 04:32 AM   #7
DIY staff
Rewards Points: 7,174
There should be a larger hole ---usually about 4"
No caulk---the cover plate has a rubber seal.
Delta Roman Tub Faucet Upgrade Issue gunderwo Plumbing 4 05-31-2012 08:40 AM
unable to stop leaky kitchen faucet w/ new valve diy888 Plumbing 0 02-27-2011 08:45 AM
Selecting a New Kitchen Faucet klumbsy Kitchen & Bath Remodeling 4 02-25-2011 08:29 AM
Ice in Cover over Exterior Faucet SPetty General DIY Discussions 13 01-11-2010 03:32 PM
Caulking Exterior Windows unixb0y Painting 1 06-04-2009 05:31 PM
