Caulking Around Bathroom Sink - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-15-2011, 07:30 PM   #1
Caulking around bathroom sink
Greetings,
A small section of the caulking around my bathroom sink, about 4 cm in length, has broken apart. From what I can see, there is no longer a complete, water-tight seal against the sink in the area where the caulking is damaged. I am reluctant to remove the caulking from this area completely, in case I end up just making the problem worse, by increasing the damaged area. (That is, I am assuming that if I try to remove the small area of caulk, I will compromise the seal at either end of the damaged area.) The seal around the rest of the sink is fine.
My question, then, is if it is possible simply to caulk over the damaged part? I've read you shouldn't put new caulk over old caulk, but I am wondering if that applies for such a small area. Can I just squeeze caulk into the space and seal it up? If not, is there a way to completely remove the damaged caulk and replace it without compromising the rest of the seal? If that is the case, what tools should I use? I briefly started this process using a very small, flat-headed screwdriver, but wonder if that the most appropriate tool. As I said, I was reluctant to finish doing this, in case I made the problem worse.
Of course, I am hoping that this is a minor issue that won't require re-caulking the entire sink! I don't think that would be within my own expertise.
My main goal is to prevent any leakage into the cabinet below, and to prevent the wood under the sink (at the top of the cabinet) from getting damp.
Thank you for any advice or suggestions you can provide.
mr_reader is offline   Reply With Quote
Old 03-15-2011, 08:18 PM   #2
IR Tech
Danko's Avatar
Hey Mr.R
yes, just go ahead and caulk over the old one. It will not be a problem as it is a very small area. Also, the caulking will mostly fill up the space, so your not really putting caulk over caulk. The other thing to consider "broken apart" implies that its stiff...if its very old you will have to re caulk the whole thing eventually, just use a exec-to knife to cut the caulking by the wall, you can probably loosen one end and just pull on it...
To redo the whole thing you'll need:
- blade knife
- > 1 tube of caulk
- rag
heres a link you might find helpful: http://www.youtube.com/watch?v=YL55y...eature=related
Hope this helps...
Danko IR Tech
Flat Roof Inspection Toronto
Insulation Inspection
Its really easier then you may think...
Danko is offline   Reply With Quote
The Following User Says Thank You to Danko For This Useful Post:
mr_reader (03-16-2011)
Old 03-16-2011, 11:56 AM   #3
Thanks for your reply, it is very helpful.
Kitchen sink backing up to downstairs bathroom! macon215 Plumbing 1 09-25-2010 06:41 PM
Remove bathroom sink from cabinet stuck with silicone Bucker Plumbing 5 09-10-2010 02:15 PM
bathroom sink drain line how small can I go? walt1122 Plumbing 3 07-02-2010 09:52 AM
Clogging/Slow Drain in Bathroom Sink AZLambdaK1 Plumbing 4 06-17-2010 05:34 PM
Reversing P-trap in bathroom sink drain? DK75 Plumbing 3 03-02-2010 01:30 PM
