Caulk Or Grout/level Compound - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-21-2013, 10:42 PM   #1
Rewards Points: 29
Caulk or grout/level compound
Hi,
I'm in the process of remodeling my guest bathroom after a complete gut job. I just want a couple of different views and advice regarding areas where I've heard many different things about.
1. Should I caulk or grout the inside corners of the tile in the shower? If caulking, any special caulk?
2. Can I tile directly on a self level eking compound (LevelQuik RS) that has a floor heating system underneath, or do I need a membrane of some sort in between?
Thanks a bunch!
Marcus
sundh is offline   Reply With Quote
Old 04-22-2013, 09:49 PM   #2
Rewards Points: 960
You should caulk all changes of plane and where dissimilar materials meet. You can use a sanded caulk from where you buy your grout. When you choose a grout color, make sure they have a caulk in the same color.
You can also use a silicone caulk, which you have to finish with mineral spirits or paint thinner. I have never used this type. It is supposed to be better.
The first type does shrink some. And it dries fast. I use a sponge to finish it with as soon as it is applied.
If you grout with urethane grout, which one might recommend, I think you can get by by using it in the corners. It is much softer than a cement based grout.
You can tile directly on the self-leveling compound.
cleveman is offline   Reply With Quote
The Following User Says Thank You to cleveman For This Useful Post:
sundh (04-22-2013)
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 36 02-24-2016 02:01 PM
How to repair a cracked driveway or walkway rfrick7@yahoo.c How To Guides 8 06-15-2015 03:59 AM
What type of Caulk to Use Einhorn General DIY Discussions 19 08-21-2011 02:50 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 05:50 PM
