Caulk Or Grout On Cap Tiles - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-23-2012, 03:19 PM   #1
Rewards Points: 79
Caulk or Grout on Cap Tiles
Im in the middle of a full bathroom makeover. We are installing tile about half way up the walls and using a decorative 1 inch border tile at the top.
I have regular grout, and also a sanded / colored caulk that we used at the base of the walk in shower / tile floor.
Should I use regular grout at the very top edge of the cap tiles where they meet the painted walls, or should I try to use some of the colored caulk along that line?
papageek is offline   Reply With Quote
Old 08-23-2012, 05:29 PM   #2
Rewards Points: 13,300
I would use caulking for a smoother water tite seal.
Old 08-23-2012, 08:38 PM   #3
DIY staff
Rewards Points: 7,174
Either will work----post a picture if you wish---
Old 08-24-2012, 09:00 AM   #4
Rewards Points: 79
Mike, Id love to post a picture. Are there instruction anywhere on the site to tell us the best way to either upload a picture directly to DIY, or how to upload elsewhere and link to DIY.
Old 08-24-2012, 09:05 AM   #5
Rewards Points: 79
Let me add another question to my original post! What is the best adhesive to use for 1 inch cap tiles? The mortar seems to be overkill and kind of thick for this purpose. The tiles themselves are very ornamental, the backs look a little like a popcorn ceiling, just a little of bumpy.
Can I, and is it a good idea to use the same caulk to mount the tiles? Since these tiles are thicker and will stand out a little from the base tiles, should I use something with more adhesive qualities to moutn them?
Old 08-24-2012, 07:12 PM   #6
DIY staff
There is a sticky at the top of the 'general discussion' forum,I think.
You should be able to use the thinset for the cap tiles---I've never had to switch setting materials for caps. Pinning with small brad nails is sometimes needed to keep them in line.
Old 08-25-2012, 12:23 AM   #7
Registered User
Rewards Points: 5,244
In the "How to" guides; http://www.diychatroom.com/f98/
Gary
Need to replace 4 3x3 ceramic tiles around shower. babaganoosh Tiling, ceramics, marble 1 12-28-2010 09:40 PM
Repairing missing grout in shower stall CLM Tiling, ceramics, marble 14 10-03-2010 11:08 PM
Self-adhesive vinyl tiles and premixed grout from Home Depot ccgnj Flooring 2 08-22-2010 08:37 AM
Grout pulled out alond with caulk on tub easybay Plumbing 0 04-09-2010 12:01 PM
Removing cured grout from surface of slate tiles Mikedks Flooring 5 09-28-2009 01:38 PM
