Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 10-13-2011, 04:11 PM   #1
Cast Iron Tub Install, PLEASE HELP??
I am installing a kohler cast iron whirlpool tub.
My current bath is new...2x10's under 3/4 tongue and grove Advantech (better plywood material (main floor). Hardibacker ¼ subfloor prepped for tile.
This tub is heavy!! 300 empty. I was looking to build an island style box. Adding a ½ plywood floor, 2x4 walls, ½ plywood top, then ¼ hardi for tile on top and around side of the tub. IS THAT OVERKILL?
Reading kohler recommends splitting the framing/surround due to its weight.
My thoughts building a box, having the 4 feet rest on the ½ plywood, then setting on the ¾ main floor would be better then it just resting on the Advantech. I also though having a island style I could remove the grout lines and pull the box out if needed then trying to remove sides of the wall of the tub.
The location is in the corner, so I would be building a knee wall in the front and on 1 side if I didn’t do the island….
ANY THOUGHTS,
tub...
http://www.us.kohler.com/onlinecatal.../1019700_4.pdf
chipraynor is offline   Reply With Quote
Old 10-18-2011, 07:25 AM   #2
The place to build boxes, IMHO, is on the house framing. Double up the floor joists under the tub/feet area and run supports between the joists. Those 4 points support all the weight.
Total weight witout a body is 770lbs, in a 3'x5' space(about 52lb/sf), design for that. Most house framing will hold 40lb/sf with no changes.
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 10:16 PM
replacing/altering cast iron supply & return lines? jeffro83 HVAC 5 05-12-2011 07:14 PM
cast iron or pvc treerat Plumbing 1 03-29-2011 07:38 AM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 11:21 AM
cast iron lavatory sink tommmy 777 Plumbing 3 03-21-2010 04:49 PM
