Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 01-03-2009, 06:36 PM   #1
Default Cast iron self-rimming kitchen sink & granite tile
Hello all,
I am working on a kitchen remodel and have already put in some of the granite tile on the countertops and backsplash and it has turned out really nice. However, I am becoming frustrated with the area around the kitchen sink. I have a beautiful self-rimming cast iron Kholer sink and 12"x12" granite tiles. I realize that an undermount sink or tile-in sink would have been a better choice for this remodel, but unfortunately it is too late to return the self-rimming sink now. I actually don't mind having the rim around the sink as my old sink was self-rimming and never seemed to bother me.
My question is how exactly should I install the sink? I have made the appropriate cut-out for the sink and have installed both the plywood and cement backerboard.
If I install the sink on to the cement backerboard and then tile up to it the tile ends up being a bit higher than the sink rim and I am left with gaps at each corner of the sink due to the sink's corners being rounded. Am I to try to make rounded cuts on my tile where it meets the sink or do I simply make square cuts and grout in the gaps? How would I even go about making a rounded cut with a simple wet-saw?
The other option is to install the sink on top of the tile. This will cause the sink to have the rim up higher than the tile (as is the way self-rimming sinks are designed) but would, in my opinion, provide a cleaner look. My only question here is would the weight of a cast iron sink end up cracking the granite that it is set on top of?
I really want to get this done so any help is greatly appreciated. Thanks.
ILjXYZ is offline   Reply With Quote
Old 01-03-2009, 07:53 PM   #2
K&B Remodeler/Tile Guy
angus242's Avatar
You should set the tiles and then mount the sink on top of them. I think it would look weird to butt the tiles against them not to mention, good luck making those cuts!
Kind of after the fact but I sure hope you used the proper sized ply and CBU. Here's a link to a member's website who pops in now and then explaining tiled counter tops:
http://www.creativeceramicandmarble....ountertops.htm
Angus
My Albums
angus242 is offline   Reply With Quote
More On This Topic
Today we are installing a vintage sink into a rebuilt counter top. What we want to do after we get the sink into the counter, with some help, is measure approximately the line of this side of the sink in the front just to make sure that it is almost the... Read More »
Today we’re installing a kitchen sink in a rebuilt counter. We already have the sink secured with the braces and everything. The next step that we want to do is to actually install the sink supply lines onto the faucet valves. You want to loosen... Read More »
Once you get all of your plumbing in. Now on this sink, the drain is set forward from the drains coming out of the sink because of the remodel. This inlet right here is going to go to the dishwasher on this side of the sink. We had to use a flexible hose... Read More »
Today we have installed a new faucet on an older sink, which we’re going to put in our new kitchen remodel. What we’re doing is we’re just going to connect the supply hoses, which can be one standard size, but they’re not. Just... Read More »
We are doing a kitchen remodel, and we’re installing the sink. We have replaced one of the supply lines, we have the sink in, and the supply line is connected to the outlet valves. Now we’re going to install a dishwasher drain. You put it on... Read More »
[IMG] code is Off
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 01:44 PM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 10:43 AM
Old cast iron sink weighs a ton ex-Khobar Andy Plumbing 7 08-29-2007 05:15 PM
Current trends: Cast Iron or Stainless Steel sink? Fat b Remodeling 4 05-04-2007 09:09 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
