Can I Use My Existing Propane Grill To Build Into An Outdoor Kitchen? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-18-2014, 04:14 PM   #1
Can I use my existing propane grill to build into an outdoor kitchen?
I have a $500 grill and don't want to spend more now that I'm building my own outdoor kitchen. Also planning on making a charcoal grill too. Not sure what to do there either, but initial design will have a metal stud design with treated 4x4 corners concreted in the ground.
chrisrieom is offline   Reply With Quote
Old 02-26-2014, 02:51 PM   #2
You sure can! That is exactly what I did with mine.
Mine was a 3 unit job - I took it apart and set it into my kitchen. If you have any more questions I'm happy to help. Pics always help illustrate any problems.
jemsander is offline   Reply With Quote
Old 02-26-2014, 02:56 PM   #3
Rewards Points: 6,652
I hope that you incorporated some type of fire suppression system also. Along with an auto shut off for the gas feed to the grill, if this is inside the house.
Old 02-26-2014, 02:58 PM   #4
There are ones made to be placed in a bricked out box for the grill. Others have taken a regular grill and just set it on to the shelf they built for the grill to sit on.
The problem that you run into, is a lot of people do this, but never think about creating drainage. Instead they make a concrete pad for it to sit on.
Replacement Aluminium Window - Reusing existing sill flashing? GrantJohnson Building & Construction 4 02-10-2010 11:27 AM
Adding receptacle on existing circuit schnitz411 Electrical 2 08-12-2009 06:15 PM
New Roof and Insulation over Existing Roof MitchellScott Roofing/Siding 1 05-03-2009 09:24 AM
Fire pit build over existing concrete deck - am I headed for trouble? mitchcos Building & Construction 10 04-15-2009 08:26 AM
Blending ceiling patch with existing sheet-rock (slight texture) gmhut Painting 3 07-29-2008 12:16 PM
