Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 08-29-2010, 06:44 PM   #1
Knows everything but that
Can I tile on a shower flange?
Im about to install cement board over my shower surround (I talked the wife into doing this over drywall) and have a question. When I install the cement board so the it touches the top of the flange, when I am tiling, do I put thinset right on the flange too? If not, since the flange is 1.5 inches, is 1.5 inches of tile on the cement board enough to stick? I am using 3 inch tile. I suppose I could rearrange and use 4 inch tile if everyone thinks Ill need more mating surface on the cement board. Thanks everyone!
Shane
JakAHearts is offline   Reply With Quote
Old 08-29-2010, 08:44 PM   #2
Super Moderator
Fill that gap with thinset AS you tile.
Old 08-29-2010, 08:59 PM   #3
Thanks mike! Though I dont understand what you mean. There is no gap to speak of that I can see. Once I put the cement board up, it will be level with the flange. Should I shim the cement board to be sticking out past the flange a bit and then fill the created gap w/ thinset? Thanks again!
Old 08-29-2010, 09:10 PM   #4
Super Moderator
Sorry,Shane---thought you were talking about a tub flange.
If you have access to a table saw--cut some thin furring strips( as thick as the fiberglass) and nail them on to the studs before the backer board.
bring the backer down to the top of the surround---cover that flange.
That area above the tub surround is not a 'wet area' and could be done with green board safely.
Good luck with that thin strip on the right--Might be tough to install---look like liquid nails and gentle screws.--Mike--
Old 08-29-2010, 09:17 PM   #5
Gotcha. Thank you! Also, thanks for the good luck.
Shane
Old 08-29-2010, 09:23 PM   #6
Also, I dont have access to a table saw but think I have a decent alternative. If I stack two shims up to the proper width and then chop off the extra, WAH-LAH! Instant proper size shims. I figure if I put two or three of these per stud and screw through them, Ill be good to go. Whatcha think?
Shane
Old 08-30-2010, 08:26 AM   #7
Tileguy
Bud Cline's Avatar
Jheeeeeezh!!!
That would be a cobbled-up mess now wouldn't it? Why not go buy a few pieces of "lattice" and use them?
The Following User Says Thank You to Bud Cline For This Useful Post:
oh'mike (08-30-2010)
Old 08-30-2010, 09:00 AM   #8
Originally Posted by Bud Cline View Post
Jheeeeeezh!!!
Im German. We love to overcompliate things. Thanks!
Shane
The Following User Says Thank You to JakAHearts For This Useful Post:
shower tile floor dougandliz Plumbing 1 08-29-2010 10:29 AM
Tile around one piece shower unit and tub golfgirl Tiling, ceramics, marble 2 03-09-2010 08:26 PM
Need help in flange extender for a new tile floor eyeglass Plumbing 6 09-17-2009 09:16 PM
Turning a tile shower into a one piece shower... chimera Remodeling 12 03-14-2009 03:30 PM
Plastic shower surround on top of tile ok? 1973vw Remodeling 4 04-09-2008 01:22 AM
