-   Kitchen & Bath Remodeling (http://www.diychatroom.com/f80/)
-   -   Can I tile on a shower flange? (http://www.diychatroom.com/f80/can-i-tile-shower-flange-79967/)
JakAHearts 08-29-2010 05:44 PM
Im about to install cement board over my shower surround (I talked the wife into doing this over drywall) and have a question. When I install the cement board so the it touches the top of the flange, when I am tiling, do I put thinset right on the flange too? If not, since the flange is 1.5 inches, is 1.5 inches of tile on the cement board enough to stick? I am using 3 inch tile. I suppose I could rearrange and use 4 inch tile if everyone thinks Ill need more mating surface on the cement board. Thanks everyone!
Shane
oh'mike 08-29-2010 07:44 PM
Fill that gap with thinset AS you tile.
JakAHearts 08-29-2010 07:59 PM
Thanks mike! Though I dont understand what you mean. There is no gap to speak of that I can see. Once I put the cement board up, it will be level with the flange. Should I shim the cement board to be sticking out past the flange a bit and then fill the created gap w/ thinset? Thanks again!
http://i104.photobucket.com/albums/m...6/DSCN6302.jpg
oh'mike 08-29-2010 08:10 PM
Sorry,Shane---thought you were talking about a tub flange.
If you have access to a table saw--cut some thin furring strips( as thick as the fiberglass) and nail them on to the studs before the backer board.
bring the backer down to the top of the surround---cover that flange.
That area above the tub surround is not a 'wet area' and could be done with green board safely.
Good luck with that thin strip on the right--Might be tough to install---look like liquid nails and gentle screws.--Mike--
JakAHearts 08-29-2010 08:17 PM
Gotcha. Thank you! Also, thanks for the good luck. :laughing::thumbsup:
Shane
JakAHearts 08-29-2010 08:23 PM
Also, I dont have access to a table saw but think I have a decent alternative. If I stack two shims up to the proper width and then chop off the extra, WAH-LAH! Instant proper size shims. I figure if I put two or three of these per stud and screw through them, Ill be good to go. Whatcha think?
Shane
Bud Cline 08-30-2010 07:26 AM
Jheeeeeezh!!!
That would be a cobbled-up mess now wouldn't it? Why not go buy a few pieces of "lattice" and use them?:yes:
JakAHearts 08-30-2010 08:00 AM
Originally Posted by Bud Cline (Post 493079)
Jheeeeeezh!!!
Im German. We love to overcompliate things. Thanks! :thumbsup:
Shane
