-   Kitchen & Bath Remodeling (http://www.diychatroom.com/f80/)
-   -   Can I tile over the window in my shower? (http://www.diychatroom.com/f80/can-i-tile-over-window-my-shower-92211/)
pumpkin8880 01-13-2011 03:44 PM
I have a 2x3' glass block window in my shower....I would like to not have the window, but the amount of work to remove it and match the stone on the outside of the house would be close to impossible. I was wondering if I could just board over the window on the inside, (insulate it ofcourse) and then tile right over it. That way it would still look like a glass block window from the exterior of the house, but from the inside, would look windowlesss?
epson 01-13-2011 04:01 PM
I would do exactly that. Frame it out on the inside and make yourself a ledge so you can put all your soaps and stuff. Use cement board, tape with the special and water proof before you add your tiles.
Jim F 01-13-2011 08:05 PM
Seems like a reasonable compromise if you really dislike the glass block window. If it can be done in such a way so as not to damage the glass blocks, that would be better still. As I understand it, those glass blocks are expensive and if you go to sell it, the future homeowner may want to open it back up.
Ron6519 01-21-2011 09:06 AM
When you do this, just be aware that you can see through the block from the exterior. Apply something to that side of the wall that won't look like you boarded up the window and won't peel and look like crap from outside.
Ron
