Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 01-03-2010, 05:01 PM   #1
Can I temporarily connect my dishwasher in utility room during kitchen remodeling?
We'll be remodeling our kitchen and I wanted to temporarily connect the dishwasher in the utility room. Can this be done safely? It would be standing next to our washer and drier and I was thinking about draining it into the same large utility sink where the washer is drained. I assume I will need to put some sort of strainer in the sink to prevent it from being clogged by the debris coming out of the dishwasher. Can the d/w be "freestanding" or do I need to secure it somehow? Thanks.
ilyaz is offline   Reply With Quote
Old 01-05-2010, 07:43 AM   #2
gravity always wins
I see no reason this wouldn't work. As far as the strainer, if your permanent installation doesn't have one, why would you need one here? Just watch the height of your discharge hose in case it doesn't like being higher than the top of dishwasher to reach into the sink. Not sure if this would even be an issue.
Old 01-05-2010, 08:24 AM   #3
Remodeling Contractor
it will work fine. Watch out as you fill and unfill since this is when it will tip over. If possible attach a cleat above it to act as a tip prevention for safety. No strainer is needed.
"pass-through" from kitchen to dining room? scoobz Building & Construction 10 12-25-2007 09:05 AM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 03:32 PM
Adding a chair rail to dining room which is connected to kitchen Bacardi 151 Interior Decorating 7 07-05-2007 04:31 AM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 04:21 PM
Utility room nightmare sgt809 Flooring 6 07-03-2006 05:27 PM
