Can I Frame With Wood On A Building Instead Of Metal Studs - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-12-2011, 10:12 PM   #1
Can I frame with wood on a building instead of metal studs
Hi I am renovating my bathroom moving toilet pipe in a 6 stories building condo. I have a 8" slab of concrete between floors. All the old structure is concrete blocks and plaster. I did the demo and I want to ask if I can use wood studs instead of metal studs.
EHouse is offline   Reply With Quote
Old 01-12-2011, 10:27 PM   #2
DIY staff
Rewards Points: 7,174
Check with the local building department and the condo board----Some towns require steel in commercial and apartments---others do not.
The gauge of steel will be specified in the code--all steel studs are not the same.--Mike--
Old 01-12-2011, 10:35 PM   #3
Rewards Points: 1,002
You are going to get several posters who will all ask "what does your permitted plan sheet say". While this is a valid answer, I'll cut to the quick.
Surely and emphatically there is little chance that you can use standard wood construction in a six storey condo of existing non-combustable construction.
By the sounds of it, I would guess that your building is an older Type I building. These buildings are built of the highest non combustible construction. Common examples are heavy steel-framed office buildings where the structural steel has been fire proofed, and residential buildings with post-tensioned concrete slab floors and steel stud walls. The different types of construction are due to occupancy loads, and occupancy types. A residential building will have less people in it, but they can be expected to be asleep.
Anti-wingnut is offline   Reply With Quote
The Following User Says Thank You to Anti-wingnut For This Useful Post:
oh'mike (01-12-2011)
Old 01-12-2011, 11:12 PM   #4
The walls in this building are of that white blocks. They are softer than the gray concrete blocks. I suppose we cannot nail wood furrings neither.
Thank you guys for your answers. I will check Building plans and with the condo board.
Old 01-12-2011, 11:19 PM   #5
I have no idea what "white block" are.
Most condo boards are composed of idiots who wouldn't know a board if it was up their a_ _ .
If you stick with metal stud construction, you won't get in trouble vis a vis construction type as long as you do not tear down/into any fire walls
Door doesn't latch with metal frame banker85 Building & Construction 4 11-23-2010 09:05 PM
Plasma Mount into Metal Studs davewolfs Home Theater 24 05-21-2009 09:23 AM
How difficult is it to learn to use metal studs? YerDugliness Building & Construction 7 08-18-2008 07:59 PM
metal studs to build up attic floor Airborne180 Carpentry 6 12-13-2006 05:02 PM
insulating metal studs - help maintenance Building & Construction 2 08-05-2005 05:31 PM
