-   Kitchen & Bath Remodeling (http://www.diychatroom.com/f80/)
-   -   Can I frame with wood on a building instead of metal studs (http://www.diychatroom.com/f80/can-i-frame-wood-building-instead-metal-studs-92140/)
EHouse 01-12-2011 09:12 PM
Hi I am renovating my bathroom moving toilet pipe in a 6 stories building condo. I have a 8" slab of concrete between floors. All the old structure is concrete blocks and plaster. I did the demo and I want to ask if I can use wood studs instead of metal studs.
oh'mike 01-12-2011 09:27 PM
Check with the local building department and the condo board----Some towns require steel in commercial and apartments---others do not.
The gauge of steel will be specified in the code--all steel studs are not the same.--Mike--
Anti-wingnut 01-12-2011 09:35 PM
You are going to get several posters who will all ask "what does your permitted plan sheet say". While this is a valid answer, I'll cut to the quick.
Surely and emphatically there is little chance that you can use standard wood construction in a six storey condo of existing non-combustable construction.
By the sounds of it, I would guess that your building is an older Type I building. These buildings are built of the highest non combustible construction. Common examples are heavy steel-framed office buildings where the structural steel has been fire proofed, and residential buildings with post-tensioned concrete slab floors and steel stud walls. The different types of construction are due to occupancy loads, and occupancy types. A residential building will have less people in it, but they can be expected to be asleep.
EHouse 01-12-2011 10:12 PM
The walls in this building are of that white blocks. They are softer than the gray concrete blocks. I suppose we cannot nail wood furrings neither.
Thank you guys for your answers. I will check Building plans and with the condo board.
Anti-wingnut 01-12-2011 10:19 PM
I have no idea what "white block" are.
Most condo boards are composed of idiots who wouldn't know a board if it was up their a_ _ .
If you stick with metal stud construction, you won't get in trouble vis a vis construction type as long as you do not tear down/into any fire walls
