Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 12-14-2012, 01:44 PM   #1
Cabinets on out of level floor
I am installing semi custom cabinets and need to deal with a 3/8" floor drop between two separate runs of cabinets separated by a refrigerator.
Doing the cabinets before the floor. My options are to shim up the low side and cover the gap to the floor with extra molding (the prefinished kick plates are not oversized). Not a big fan of the cluttered look this might lead to.
Another option would be to build up the finish floor to take care of the gap, which should be OK since the dishwasher is on the low side of the kitchen.
A third option I am considering since the run is broken is simply to reset the level for the second run meaning that on the low side of the floor the cabinets would still be ~34.5" off the floor. Not sure if the 1/2" countertop offset would be noticeable when broken up by the fridge.
Any advice as to the best way to proceed would be greatly appreciated.
naulleau is offline   Reply With Quote
Old 12-14-2012, 01:55 PM   #2
Super Moderator
Are you dealing with a single high place that raised the first bank of cabinets? If so--shortening the bottoms of the cabinets is an option--
I think ordering or making a new taller toe kick might be a simple solution---
The big trouble with uneven counter height happens when the back splash gets tiled----
Old 12-14-2012, 02:16 PM   #3
Super Moderator
Why are you installing the cabinets before the new floor?
How thick is the new flooring? Will that screw up the clearance for the fridge and dishwasher?
Old 12-14-2012, 02:23 PM   #4
Not a single low spot. The entire floor is sloped so one side of the kitchen is 3/8" lower than the other. Good thought on the wider kick plates. The backsplash will not be continuous since I have the fridge in between the two sections.
Old 12-14-2012, 02:27 PM   #5
I have already built up the floor under the cabinets to compensate for the tile thickness. Did a lot of research into the pros and cons of doing finish floor before and after and in the end decided to go with doing the finish floor after.
Old 12-14-2012, 02:29 PM   #6
Super Moderator
I doubt if any one but you will see the height difference----If I had a vote--it would be for 3/8" height difference--
Old 12-14-2012, 02:34 PM   #7
Super Moderator
Just a note---I've never done that---I always find a way to keep the counters the same height---
woodworkbykirk (12-14-2012)
Old 12-14-2012, 02:39 PM   #8
So in this particular case you would break your rule of "ALWAYS" keeping the counters at the same absolute height?
Thanks for all the feedback.
Old 12-14-2012, 02:44 PM   #9
Super Moderator
I get paid to do things in the ideal fashion---so I would do it so all counters are the same height----no call backs and unhappy customers---
However---if it were my house and I was the 'customer"? I'd install it out of plane and never think of it again---
Old 12-14-2012, 03:26 PM   #10
journeyman carpenter
woodworkbykirk's Avatar
if anyone with a even semi good eye will notice the height difference immediately.. if your worried about the dishwasher clearance after the finish floor is installed determine the height required where the washer goes and use that as your benchmark.. from that point strike a level line all the way around where the cabinets are going and shim them to be at the line
woodworkbykirk is offline   Reply With Quote
Old 12-14-2012, 03:41 PM   #11
Thanks. The only thing I was worried about is cleanly taking care of the gap I will have from the cabinet to the floor on the low side of the floor. The options I have considered in that case are 1) extra shoe molding that I don't really like, 2) get wider kick plate that I can cut down to size, 3) raise the whole finish floor to take care of the gap, this would work since the dishwasher is at the low point and thus the dishwasher would end up with exactly 34.5" from finish floor to top of cabinet.
Old 12-14-2012, 04:15 PM   #12
"Nail-Bender"
Find the high point of the floor -
Start there -
Shim the cabinets up to level - at the lower spots of the floor -
(Don't assume the walls are straight - might have to shim between the
walls and the cabinets).
I don't know the layout of the kitchen - cabinets on both sides?
Cover the gap at the bottom with the "kick-plate".
Keep the counter-tops level!
A handful of marbles, rolling across a counter-top sure does show things!
rossfingal is offline   Reply With Quote
The Following User Says Thank You to rossfingal For This Useful Post:
joecaption (12-14-2012)
Old 12-14-2012, 04:21 PM   #13
The last post is the best option.
Counter tops and the cabinets have to be level, the kick plate and 1/4 round will make up for where it's off.
Old 12-14-2012, 04:22 PM   #14
So your recommendation is to replace the stock kick plates with wider ones that I can cut to size?
Old 12-14-2012, 04:24 PM   #15
"Nail-Bender"
Yes!
Keep the counter-tops level - right to left and front to back!
Tags
cabinets, level
How to level bathroom floor papageek Remodeling 2 06-01-2012 08:25 PM
Level Basement Floor with Floor Grinder? butchbs1985 Flooring 4 08-26-2011 07:18 PM
Raising the level of concrete floor chandan.cogni Flooring 3 12-30-2010 07:37 AM
Floor or cabinets first? bob22 Flooring 11 09-03-2010 08:40 AM
Q about Humidity Level... Okay for Wood Floor? Ininkus Flooring 8 01-23-2009 10:58 AM
