Cabinet Knobs - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-20-2012, 12:24 AM   #1
Cabinet knobs
Should I install cabinet knobs on doors which are side by side by marking placement for one knob and using a level for placement of the other knob since the doors are hung a tad unlevel? I installed a couple of the knobs using the same measurements and they are not level with each other.
Beckaroo is offline   Reply With Quote
Old 03-20-2012, 12:29 AM   #2
Rewards Points: 14,306
What type hindges do you have? Some are adjustable. Not sure what type you have just post a picture.
The knobs need to be level or it's going to stick out.
Old 03-20-2012, 12:42 AM   #3
I have reverse bevel hinges which are mounted on back of cabinet door and face of cabinet and cannot be moved or I would have holes to patch and marks to repair.
Old 03-20-2012, 12:49 AM   #4
Look these?
http://www.usacabinethardware.com/cg...a=b&cnid=66030
No such thing as reverce bevel so I'm going to guess there offset hindges if there are not the ones I post the website for.
Old 03-20-2012, 12:55 AM   #5
No, not those but if you click on overlay hinges, mine are a self-closing reverse bevel variable overlay hinge. My cabinets are older.
Old 03-20-2012, 12:58 AM   #6
Just install one knob and use a Topedo level when marking the next one.
Old 03-20-2012, 01:03 AM   #7
Ok, thanks. I've got a small level I'm using.
Old 03-20-2012, 05:33 AM   #8
DIY staff
Rewards Points: 7,174
There are nice plastic templates available in the knob isle of the stores----makes positioning knobs easy.
Worth a buck or two if you have several to install.
Old 03-20-2012, 07:34 AM   #9
I purchased these templates. There's one for doors and one for drawers. I'm thinking about $3 each
Doorman54 is offline   Reply With Quote
Old 03-20-2012, 11:00 AM   #10
I've got the templates. The problem is...if I drill the holes in the same location on both doors, if the doors are off a bit the knobs are not level.
Old 03-20-2012, 05:22 PM   #11
DIY staff
Adjust the doors-----It will look goofy to have crooked doors with level knobs---
Fancy hinges have two or even three adjustment screws----simple surface mounted hinges are adjusted by bending the hinge a bit---
Old 03-20-2012, 05:29 PM   #12
I agree with Mike....."perfume on a pig" I believe is the saying.
No disrespect meant
The Following User Says Thank You to Doorman54 For This Useful Post:
oh'mike (03-21-2012)
Need help! Cabinet install gone slightly wrong eemichael83 Carpentry 14 10-26-2010 03:46 PM
Kitchen Cabinet Knobs and Free Standing Island Ttbsjdzm Kitchen & Bath Remodeling 4 06-01-2010 11:49 PM
A question about cabinet knobs and continuity... juliebun General DIY Discussions 6 05-07-2009 08:46 AM
