Cabinet Crown - Kitchen & Bath Remodeling - Page 3 - DIY Chatroom Home Improvement Forum
Old 03-02-2014, 12:41 PM   #31
DIY staff
Rewards Points: 7,174
Concave ? Two likely suspects---the wood moved as you cut it--or the blade deflected--to end the deflection---cut the piece a tiny but long--adjust the board and make the final cut---
third possibility? Sloppy saw----check for head movement---
Old 03-02-2014, 09:39 PM   #32
Rewards Points: 142
wood didn't move. and i cut it slow. didn't check for slop.
Fix'n it is offline   Reply With Quote
Old 03-02-2014, 10:29 PM   #33
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Are you cutting the ceiling mold like you have it setting on the saw? If so, you have it on the saw backwards.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 03-02-2014, 10:38 PM   #34
Rewards Points: 142
yes, i am cutting it that way. the angle works out well. its just the cut on one side.
how should i be doing it ?
Old 03-02-2014, 10:58 PM   #35
Rewards Points: 142
ok. i just went and turned the pieces face up. then would cut them from the opposite side of the saw. that right ?
Old 03-02-2014, 11:51 PM   #36
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
If you were to take a piece and place it on the ceiling correctly then take that piece down and place it on your miter saw upside down (not backwards) from the way is was on the ceiling and bedded into the saw, that would be the correct way to cut it. When I say bed it into the saw, see the flats that touch the wall and the flat that touches the ceiling, make sure they are making complete contact as if on the ceiling except upside down. You cut ceiling mold upside down and backwards.
Jim
The Following User Says Thank You to BigJim For This Useful Post:
Fix'n it (03-03-2014)
Old 03-03-2014, 12:08 AM   #37
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Here is a picture of ceiling mold bedded in the miter saw I found on the web. Notice that the molding is upside down on the saw, that is the correct way to cut the molding.
Jim
The Following 2 Users Say Thank You to BigJim For This Useful Post:
Fix'n it (03-03-2014), oh'mike (03-03-2014)
Old 03-03-2014, 09:24 PM   #38
Rewards Points: 142
ok. then that is the way i will do it. i will give it another go this weekend.
The Following User Says Thank You to Fix'n it For This Useful Post:
BigJim (03-03-2014)
Old 03-23-2014, 09:36 PM   #39
Rewards Points: 142
ok. i installed much of it today. i didn't use a jig, nor the angle gauge. and the saw was working correctly today. i miss cut 2 pieces, not paying enough attention . but otherwise the cuts came out well enough.
what i did have a very hard time with = getting them mounted correctly. just a little off would be noticable. i needed 3-4 hands, and i only have 2. so i just fought with it the best i knew how.
it turned out pretty good, not great, but pretty good.
see my sample backsplash tiles. i have yet to find anything that i like. but the wife LOVES the glass mosaics . i think they are too busy.
Old 03-24-2014, 07:37 AM   #40
DIY staff
that's looking good!
Old 03-24-2014, 08:35 PM   #41
Rewards Points: 142
yeah, it does. i am suprised at just how much it "add's" to the room. the room seemed kinda naked before. and i still have another bank of cabinets to do. plus the over fridge cabinet.
Cabinet crown molding Vadim Carpentry 6 11-26-2011 09:31 PM
Cabinet Crown Molding highchile Carpentry 1 02-24-2010 04:49 PM
Cabinet Crown Molding and Hood Range? gate1way2 Carpentry 3 10-16-2008 12:13 AM
crown angle for corner cabinet... kemerick Carpentry 8 10-24-2007 10:54 PM
