Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 01-29-2009, 08:56 PM   #1
Default Bypass Shower Doors Install Question
DIY tile job in master bath. Bypass shower doors to be installed in a few days. What steps should I be checking on during the install? Redid this bath due to mold--would hate to set off same problem due to incorrect install.
houston is offline   Reply With Quote
Old 01-29-2009, 11:23 PM   #2
Man of many hats
wrangler's Avatar
Bypass doors are the easiest of shower doors to install, hence why all the box stores sell them off the shelf. Not a lot to know about installing them other than make sure that they are sealed along the inside to prevent water from getting under the tracks and causing mold. This includes where the bottom track meets the verticle tracks . Clear silicone caulk usually works the best as it will not clash with either the tile color or the track color. If there are gaps between the tracks on the outside of the doors where it meets the tile, caulk along there as well. But remember, sometimes less is more, meaning don't caulk just to be caulking. Water wont intrude from outside of the shower. Newer bypass doors have the wheels along the top rail which is supported by the side rails. So, even if they are installed on a fiberglass/acryllic system, the side tracks are merely supporting the top rail and the screws along the vertical/side tracks just hold them upright. I have seen 'good doors gone bad' due to installers 'over caulking'. Not that it hurts the door, but that you now have unsightly caulking spread along the outside, visible edge, of the track.
Man of many hats
wrangler is online now   Reply With Quote
Old 01-30-2009, 10:59 AM   #3
Thanks--very helpful info.
We installed a 2' tall shower enclosure base with seats instead of regular shower pan & installed the tile & backer board in the wrong place (flush against studs instead of adding a sheet of backer or drywall 1st.) So there are about 3" difference between top of where shower doors will be and bottom. The installer will apparently cut to fit and they have added 3-4 extra side panels so there will be enough frame on the sides to support the glass.
Should I add an antimold caulk over the clear silicone the installer uses? I see you don't love overusing caulk, but need to avoid future mold issues.
Old 01-30-2009, 08:22 PM   #4
Man of many hats
wrangler's Avatar
You're quite welcome, and the intstaller may very well be using a mildew resistant sealant. You can ask him, or just go ahead and purchase a tube of GE Silicone II Clear. It has what GE calls bioseal, an anti-mildew additive.
Man of many hats
Old 01-31-2009, 09:55 PM   #5
thanks.
More On This Topic
You're thinking of replacing those old, worn out sliding shower doors with a new pivot-type of shower doors. There are lots of things to consider while selecting the right type of shower doors for your shower. Here's how to buy the right type of shower... Read More »
Cleaning the bathroom can take a lot of elbow grease and some household cleaners don't seem to work on everything you need it to. Still another use for WD-40. It's more economical than having a whole buffet of cleaners to choose from and it won't harm... Read More »
Hello! I'm Daniel on behalf of Expert Village. In this clip we're going to be talking about what not to do when trying to secure a sliding glass door in your home. All too often people will stick a wooden dowel or even a metal dowel in the door. Or... Read More »
Keeping your bathtub clean means cleaning it weekly and maintaining it daily. If you do this, and follow the steps provided, you'll save yourself a lot of scrubbing and you'll keep your tub looking nice and clean. Read More »
Caulking a New Shower
Caulking a New Shower by Expert Village
Now, all the seams everywhere have to be caulked and sealed. That's what we're about to start doing now. We're going to come along here and caulk this, where it meets the shower pan. Where the frame meets the shower pan has got to be caulked. It states... Read More »
[IMG] code is Off
Shower has drywall (not green) can I install Cement board Right over it? jwhiteuwc General Discussion 14 02-03-2009 04:20 PM
How to install a preformed shower base Ironman Plumbing 2 01-15-2009 10:36 PM
want to install blinds on sliding doors joy0912 Interior Decorating 2 09-26-2007 08:18 PM
Install floating floor or my doors first? jtr Flooring 3 11-16-2006 11:21 PM
Shower stall question... Alan Remodeling 1 05-31-2006 08:57 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
