Butting 2 Pieces Of Formica - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-06-2012, 07:28 AM   #1
butting 2 pieces of formica
I need to join 2 pieces of formica at a 90 degree angle, any tricks for minimizing show at the seam?
Thanks for any help
Joe Tilghman is offline   Reply With Quote
Old 08-07-2012, 05:25 AM   #2
Too Short? Cut it Again!
Usually the 90 degrees is mitered. Try cutting the Formica at a very slight angle so the top lines up but material under it is ever so slightly further from the seam but still part of it.
Wax paper will help you align things.
Old 08-07-2012, 11:55 AM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
Use a good straight edge and router with a bearing on the end of the cutter to ride on the straight edge. Buy a HPL file, it will come in very handy, also you can buy seam filler to match your HPL if you make a goof up. I always used 1/4 inch strips of wood under the HPL to keep the glue from grabbing while positioning the HPL.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 08-07-2012, 12:43 PM   #4
Thanks all for the responses
laying laminite countertop (formica) across multiple pieces of plywood av-geek Carpentry 5 06-10-2012 08:15 AM
Custom window, bend or cut the curved pieces? SteveB87 Carpentry 15 06-07-2012 10:28 PM
Bonding formica to old formica MajorMedicalBoy General DIY Discussions 16 11-24-2011 08:45 PM
crown molding fitting problem momof2labs Carpentry 16 10-15-2011 12:45 PM
can I apply formica over formica? DIYWayne General DIY Discussions 7 12-28-2008 03:19 PM
