Build UP My Floor - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-12-2012, 07:15 PM   #1
build UP my floor
I inherited this mess!!!
The bathroom ( that hasn't been), is getting closer.. I am on OSB but brought in a temporary vanity, and will plumb it up and set a toilet...
anyway,.. the bathroom is long, like 12 x 30! (he had ideas for a hot tub room on the end, but I want to just make it all part of the bathroom).
so.. I figure I will step UP the back part, probobly 12x10, It will then have a step, but she can have a nice powder room, whatever.
This way I can run a heat duct in there and maybe a drain?
I was thinking 2x6 joists, but never THOUGHT about attaching them till now! toenail, glue? do they make brackets? I have only seen the HANGERS.
I figure there MUST be a way, and I am not the first to do this. I just can't think of how! I imagine on a regular one you frame it in like a wall. (box) but I can't here..... any advice is appreciated... dan
sixty7flh is offline   Reply With Quote
Old 04-12-2012, 07:43 PM   #2
DIY staff
Rewards Points: 7,174
A little more info,Dan.
You mentioned OSB---Is this a framed structure? What is under the room now? Can plumbing and heat go under there?
How high do you wish to raise the stepped up area?
Could you simply set 2x6s on the existing floor?
Old 04-12-2012, 08:55 PM   #3
yep.. that's what I want to do.. put 2X6's over the existing floor.. which is 2X12 on 16... then 3/4 (ish) osb.. I cannot run anything under the existing as it is actually a 2nd story overhang. I DID, put r -30 in there and then plastic and soffit stuff to hopefully keep the cold out. I am in northernmost indiana.
so.. since I cannot build a floor then FIT it in there, what toenail and glue?
Old 04-12-2012, 09:05 PM   #4
Rewards Points: 14,276
Just guessing since no pictures or drawings were posted, but it should be as simple as attaching some 2 X 6's to the wall studs on three sides and one across the room to connect into the ones on the walls, then filling in the middle with 2 X 6's every 16" on center.
It will end up looking like a wall laying down.
I would use blocking not hangers between the floor joist.
Attach 3/4" Advantec T & G over it with constrution adhesive on top of the floor joist and use ceramic coated screws to hold it down.
Old 04-13-2012, 07:07 AM   #5
attach to the wall suds.. ahh! blocking.. i'll look for 'em.. hey. thanx so much! gonnae TRY and get the floor in soon....
How to frame new floor to match existing floor height taylor01 Carpentry 4 04-04-2010 08:59 PM
Radiant floor heat under 3x8 feet wide strip of tile - how to build up rest of floor? lazzlazz Flooring 2 03-31-2010 05:52 AM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 06:11 PM
Old old linoleum, can it take paint? molamola Painting 23 11-11-2008 06:32 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
