Blocking Behind Base Cabinets? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-15-2013, 06:08 PM   #1
blocking behind base cabinets?
Do you put 1x4 blocks or cleats behind base cabinets?
Are cleats or blocking needed on the wall behind the base cabinets? My laminate overhang is now about 1 3/4". My sink is butted to the backsplash and barely fit inside the face of the sink base cabinet. I had to trim out some on the inside of the sink base frame. Clamping the sinking was hard due to limited clearance. I'm not quite flush with the wall behind the sink counter, there is a 1/8" gap from wall to backsplash, I should have scribed a little, still think the overhang is a lot. What do you think?
ees789 is offline   Reply With Quote
Old 08-15-2013, 06:52 PM   #2
Rewards Points: 12
Under normal situations, no blocking. Shims may be needed to keep the cabinet fronts straight and the backs tight to the wall.
Dan
djlandkpl is offline   Reply With Quote
Set shower base in mud svaic00 Plumbing 2 06-06-2013 08:27 PM
Installing a Sterling shower receptor in a mortar base repoocaj Plumbing 2 11-19-2011 08:52 AM
in wall blocking for cabinets BlueBSH Building & Construction 4 10-04-2011 09:26 PM
How are the premade HD and Lowes Cabinets? twilightcall Carpentry 10 05-25-2008 11:23 AM
Base cabinets on floor TonyD Carpentry 15 10-23-2006 11:53 PM
