Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 09-26-2010, 02:28 PM   #1
bathtub subfloor drain pit
Under my tub there is a hole in the slab for the trap and the connection to the cast iron main. Its just dirt under there and I've dug it out and removed all the old pipe I can easily get to. When I am done replacing (with abs) should I be doing something about the exposed dirt like covering it with lime or cement?
There was some flaky white stuff covering the dirt, but it could have been left over plaster the builders 'swept under the rug'.
tns1 is offline   Reply With Quote
custom bathtub Andy21 Kitchen & Bath Remodeling 8 10-28-2010 01:58 AM
bathtub rough in question: slip joint or glue pttcc Plumbing 2 09-16-2010 08:12 AM
Fibreglass Bathtub Leaks Need Help cookerz Plumbing 5 02-02-2010 01:40 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 06:45 AM
