Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 07-16-2011, 05:53 PM   #1
bathtub one piece wall and tub replacement
when using a one piece tub/wall surround, do I need to remove the tile on the walls above the tub before putting in the liner?
bobbierosebud is offline   Reply With Quote
Old 07-16-2011, 06:01 PM   #2
Super Moderator
Those are mounted to the studs--so yes the walls must be stripped.
One piece tub and surround units are typically used only in new construction because they will not fit through the door and turn into the room.
Tub with a three piece surround is what is used most frequently in remodeling.---Mike---
