Bathtub Nailing Flange - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-24-2010, 10:15 AM   #1
Bathtub nailing flange
From what I understand, wood furring strips should be used above the nailing flange so that cement board will lay flush over the flange... is it critical that the cement board be flush against this flange or is it okay if there is a small gap between them? In other words, how important is it that the cement board is sitting against the nailing flange where it overlaps it? or can it be slightly sticking out and not touching the flange?? Thanks
escoleone is offline   Reply With Quote
Old 04-25-2010, 02:21 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That works fine if the effected wall(s) don't meet up with a continuing wall.
Just stop the board above the flange, seal the crack and call it good. Then use thinset to fill the void when installing the tile. It's done like that all the time.
You could also notch the back of the board to accommodate the flange of the tub.
XXX
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 08:16 PM
Closet flange gap kgifford Plumbing 5 03-12-2010 08:22 AM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
Drywalling over Shower Surround nailing flange dylanm Remodeling 2 12-28-2007 07:20 AM
Flange Help Needed tajones44 Plumbing 2 07-11-2005 04:42 PM
