Bathtub Installation Issue- - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-23-2016, 04:29 PM   #1
Rewards Points: 6
Question
Bathtub installation issue-
We realize that the gentleman who installed our tub did not put in a stringer. Unfortunately, we did not realize this until we already starting putting up most of the concrete board around the tub.
I have access to both sides. I can get it from a closet on one side, and I have to rip out the vanity to get to the other side.
Is there a way to fix this without taking down everything we did?
If we called a plumber to install the tub should he have known to put the stringer in, or should we have had this set up for him? I'm not sure what the expectation is.
We're in a bit of a panic, but aren't really sure how bad this is. We're just really hoping there's a way to fix this without ruining all the work we've already done. Plus, I think if we move the tub we'd have to call the plumber again for a re-install. Which would be expensive.
Any help would be really appreciated.
Thank you,
Sam
alaskanpixie is offline   Reply With Quote
Old 07-23-2016, 05:42 PM   #2
DIY staff
Rewards Points: 7,174
Re: Bathtub installation issue-
A few more details?
Not all tubs require a stringer board---what tub ? does the instructions for that tub ask for a stringer board?
Old 07-23-2016, 06:17 PM   #3
Rewards Points: 144
I'm with O Mike on more info.What type of tub?I'm assuming when you say stringer you are talking about what we call a ledger board?Was the tub set in a mud bed?
mako1 is offline   Reply With Quote
Old 07-23-2016, 08:50 PM   #4
Rewards Points: 6
The instructions do call for a stringer board and is not on a mud bed.
The stringer board seems to be a support beam that's secured to the wall, opposite of the tub skirt.
Old 07-23-2016, 08:51 PM   #5
Rewards Points: 6
Sorry. It's also a steel and porcelain tub
Old 07-24-2016, 06:49 PM   #6
firehawkmph's Avatar
Rewards Points: 1,800
I just installed an Americast tub, which also called for a ledger board opposite the skirt. Without it, I don't see what's going to keep that tub from wiggling around when somebody steps on it. I also set mine in a bed of mortar due to the floor not being perfectly level. If you have access from the other side, you might be able to somehow get a 2 X 4 in and secure it up against the skirt of the tub. I would double check and make sure the tub is sitting level in both directions also.
Mike Hawkins
firehawkmph is online now   Reply With Quote
Tags
bathroom , installation , panic , wrong
Stuck on Bathtub Installation trophywalleye Plumbing 13 02-02-2011 03:45 AM
countertop installation - stove/oven issue diycarguy Building & Construction 12 05-04-2009 02:08 PM
Fan Wiring Installation Issue cca10 Electrical 1 05-03-2009 06:29 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 01:19 AM
Bathtub backerboard installation brucejy Building & Construction 2 10-13-2008 11:03 AM
