Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 01-02-2011, 03:48 PM   #1
bathtub insert
It seems my bathtube insert (ReBath) has separated from the tub. Can I do something to repair it or do i need to call in an expert?
dolores1130 is offline   Reply With Quote
Old 01-02-2011, 04:05 PM   #2
the Musigician
DangerMouse's Avatar
bathtub insert
dolores: how long ago was it done? I'd certainly call THEM to come back and fix it.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 01-02-2011, 05:02 PM   #3
bathtub insert
It's years ago.........
Old 01-02-2011, 05:09 PM   #4
the Musigician
bathtub insert
I'd call them first and see what they say.
DM
Old 01-02-2011, 05:34 PM   #5
bathtub insert
Those services are VERY expensive, almost as expensive as installing a new tub and tile (sometimes MORE!).
I would call them to complain and keep on them. I'm willing to bet that their sales pitch was how you would have such a fantastic bathroom for so many years, make them honor their word.
General is offline   Reply With Quote
Old 01-10-2011, 08:39 PM   #6
bathtub insert
My understanding is that they have a lifetime guarantee against that sort of thing. I think it is even transferable. Isn't that how they justify charging as much as they do?
Jim F is offline   Reply With Quote
Old 01-10-2011, 09:40 PM   #7
bathtub insert
Thanks for the input. Got some info off the internet and my husband loosenend the drain (NOT an easy task) and there was water that had apparently gotten between the liner and tub. Once the water drained, the liner went back into place. We will re-caulk because the water must be getting in through where the caulk is separating.
Old 01-11-2011, 08:00 AM   #8
the Musigician
bathtub insert
I'd recommend using 100% silicone to seal it, not just 'any old caulk' for bathrooms, which may not have enough silicone to do the job well. Po)
DM
Old 01-11-2011, 02:28 PM   #9
Smile
bathtub insert
Thanks so much for the good advice. Will use silicone as you recommend.
Old 01-11-2011, 02:40 PM   #10
the Musigician
bathtub insert
The 100% silicone that says "for use on aquariums" would fit the bill well.
DM
Old 01-12-2011, 03:40 PM   #11
bathtub insert
More good advice. Thanks!!!!!
Old 01-19-2011, 02:11 PM   #12
bathtub insert
Dolores,
Sorry to hear about the issues you're having with your bathtub. Please contact your local franchise to discuss getting this fixed. You can locate them here. http://www.rebath.com/find-a-re-bath-location/
If you have any questions or concerns, please don't hesitate to contact Lisa O’Rander in the Re-Bath customer service department directly at (480) 844-1575 ext. 147 or by email at lrizzo@rebath.com (CC me at Rachael@rebath.com).
Rachael, on behalf of the Re-Bath corporate office
RachaelwReBath is offline   Reply With Quote
Old 01-19-2011, 02:19 PM   #13
the Musigician
bathtub insert
Thank You for your response, Rachael.
We hope she can get this problem resolved with minimum or zero expense on her part.
And Thank You also for following forum rules.
DM
Fireplace Insert Chimney Liner installation eric859 HVAC 11 03-04-2011 04:58 PM
Cold Air Coming In From Bottom/Underneath of Gas Fireplace Insert mark2741 HVAC 7 12-10-2010 10:05 PM
Threshold insert j.logan Carpentry 0 09-30-2010 07:47 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 06:45 AM
