Bathtub On Cement Floor - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-25-2009, 04:18 PM   #1
bathtub on cement floor
We recently pruchased a used jacuzzi tub. I bought new plumbing for the drain and overflow. I am installing this in our basement but I am a little confused. I have a 4" pipe sticking out of the floor about 3" or so. Inside this pipe is the 1 1/2" drain. With the drain on the tub being flat to the floor right now, how do I do this? Do I need to cut the cement away or can I elevate the tub with a platform?
kodeblue is offline   Reply With Quote
Old 05-26-2009, 06:12 AM   #2
If it is the standard type tub, you need a P trap at the drain, and it usually is below the tub level. So you either need to dig a hole for the trap, or raise the tub.
Old 05-26-2009, 09:26 AM   #3
Rewards Points: 352
You need to cut the cement and dig out enough to reduce the pipe to 2" and get a trap in there that will accept the waste and overflow from your tub. You can use a drum trap to save a little space. Properly placed the drum trap could allow access via a smaller opening. You do not want to use a standard P-trap. The trap needs to be the type that is glued in place. You do not need a leak under the cement.
Rege
RegeSullivan is offline   Reply With Quote
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
Cracked cement floor in garage. gante Building & Construction 9 02-26-2009 11:55 AM
Best way to ensure flat floor between two cement board slabs? MeasureTwiceCutOnce Flooring 10 09-16-2008 11:20 PM
Basement cement floor Sftail2 Painting 4 03-28-2008 07:40 AM
Floating floor over cement gwendda Flooring 4 07-18-2006 04:58 PM
